Hp30 - JeepForum.com
post #1 of 50 Old 10-03-2012, 11:21 AM Thread Starter
goldeagle06
Hp30
Are the axle shafts and everything other than gears the same in a hp30 compared to a lp30? I know the gears turn opposite.
goldeagle06 is offline
post #2 of 50 Old 10-03-2012, 11:25 AM
Jason
R&P are different. Shafts, carrier, etc. are the same between the two.
Jason is offline
post #3 of 50 Old 10-03-2012, 11:27 AM Thread Starter
goldeagle06
Alright thanks. I was wondering because I'm looking to regear my tj and would like to upgrade to a hp30 and I was hoping I could just get the housing somewhere
post #4 of 50 Old 10-03-2012, 11:32 AM
sjones26573
Depending on what you regear from and to, might beed a new carrier.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #5 of 50 Old 10-03-2012, 11:34 AM
KingtheZJ
if you are regearing there is not reason not to move to an hp30.
and ftr, the carrier break is 3.55/3.73. the vast majority of XJ hp30 are 3.55.
the YJ also and an HP30 and gears from those can be found in 4.10 very easily. any other gears are aftermarket
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #6 of 50 Old 10-03-2012, 11:35 AM Thread Starter
goldeagle06
I have 3:73s now and lookin to go to 4:56 or 4:88.
post #7 of 50 Old 10-03-2012, 11:35 AM
Jason
He has 3.73s, which is good for 3.73 and numerically higher. I assume he's not going the other way.
Jason is offline
post #8 of 50 Old 10-03-2012, 11:38 AM
sjones26573
I know the carrier break. I didn't know what his current ratio was.
Jeep-Owner.com
post #9 of 50 Old 10-03-2012, 11:39 AM
KingtheZJ
i cant see any reason to pillage the LP30 to build the HP. a LP30 with no gears is worth $10 scrap.
complete hp30 (3.55 gears) - $100
d30 3.73+ carrier - $40
gears - $150
install kit -$120
'88 XJ
post #10 of 50 Old 10-03-2012, 11:40 AM
Jason
Click that little down arrow next to his vehicle type and you would know.
Jason is offline
post #11 of 50 Old 10-03-2012, 11:48 AM Thread Starter
goldeagle06
The hp30 is actually stronger than the lp30 isn't it?
post #12 of 50 Old 10-03-2012, 11:50 AM
KingtheZJ
yes. ive heard reports that the engineers at dana say the gears in an hp axle can be up to 30% stronger than the same size in an lp setup. it stems from the way the gears mesh and the deflection of the ring gear.
'88 XJ
post #13 of 50 Old 10-03-2012, 12:07 PM Thread Starter
goldeagle06
I was just gonna buy a hp housing and put everything in it from my axle to save some money
post #14 of 50 Old 10-03-2012, 12:14 PM
sjones26573
I'm on an iPhone bub.
Jeep-Owner.com
post #15 of 50 Old 10-03-2012, 12:24 PM Thread Starter
goldeagle06
Is a hp30 out of a Xj a direst bolt in to my tj or will i have to modify it
