-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   Hp30 (http://www.jeepforum.com/forum/f19/hp30-1423694/)
goldeagle06 10-03-2012 11:21 AM
Hp30
Are the axle shafts and everything other than gears the same in a hp30 compared to a lp30? I know the gears turn opposite.
Jason 10-03-2012 11:25 AM
R&P are different. Shafts, carrier, etc. are the same between the two.
goldeagle06 10-03-2012 11:27 AM
Alright thanks. I was wondering because I'm looking to regear my tj and would like to upgrade to a hp30 and I was hoping I could just get the housing somewhere
sjones26573 10-03-2012 11:32 AM
Depending on what you regear from and to, might beed a new carrier.
KingtheZJ 10-03-2012 11:34 AM
if you are regearing there is not reason not to move to an hp30.
and ftr, the carrier break is 3.55/3.73. the vast majority of XJ hp30 are 3.55.
the YJ also and an HP30 and gears from those can be found in 4.10 very easily. any other gears are aftermarket
goldeagle06 10-03-2012 11:35 AM
I have 3:73s now and lookin to go to 4:56 or 4:88.
Jason 10-03-2012 11:35 AM
He has 3.73s, which is good for 3.73 and numerically higher. I assume he's not going the other way.
sjones26573 10-03-2012 11:38 AM
I know the carrier break. I didn't know what his current ratio was.
KingtheZJ 10-03-2012 11:39 AM
i cant see any reason to pillage the LP30 to build the HP. a LP30 with no gears is worth $10 scrap.
complete hp30 (3.55 gears) - $100
d30 3.73+ carrier - $40
gears - $150
install kit -$120
Jason 10-03-2012 11:40 AM
Click that little down arrow next to his vehicle type and you would know. :D
goldeagle06 10-03-2012 11:48 AM
The hp30 is actually stronger than the lp30 isn't it?
KingtheZJ 10-03-2012 11:50 AM
yes. ive heard reports that the engineers at dana say the gears in an hp axle can be up to 30% stronger than the same size in an lp setup. it stems from the way the gears mesh and the deflection of the ring gear.
goldeagle06 10-03-2012 12:07 PM
I was just gonna buy a hp housing and put everything in it from my axle to save some money
sjones26573 10-03-2012 12:14 PM
I'm on an iPhone bub.
goldeagle06 10-03-2012 12:24 PM
Is a hp30 out of a Xj a direst bolt in to my tj or will i have to modify it
The time now is 07:20 PM.
