HP Dana 30 Q's - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > HP Dana 30 Q's
Cold Air Intake and Throttle Body Spacer KitKrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 10-02-2012, 02:54 AM   #1
justntime911
HP Dana 30 Q's
I have a 06 LJ. I'm wanting to swap in a HP Dana 30. I'm going to be running 35 KM2's. What jeep do I need to get the HP dana 30 out of? I'm wanting to get one that will bolt right in. I know most of the ones in the cherokee's came with 3.55 gear. Did they make them with 3.73 or 4.11 from the factory? Any info would be very much appreciated!
justntime911 is offline   Reply With Quote Quick reply to this message
Unread 10-02-2012, 06:31 AM   #2
mdm
Farm Wheeler
All XJ front axles will bolt into a TJ with no modifications. '96 - '99 XJ are the best years to look for. They don't have the shaft disconnect and do have the same knuckles and u-joints your '04 has. Prior to '96 they had the smaller u-uoints but you can use your current shafts. Go back a few more years and you get into things like the shaft disconnect and a two piece knuckle. They did come with 3.55, 3.73, and 4.10 gears.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote Quick reply to this message
Unread 10-02-2012, 01:05 PM   #3
justntime911
Thanks for the info mdm!
