HP Dana 30 Q's - JeepForum.com
post #1 of 3 Old 10-02-2012, 02:54 AM Thread Starter
justntime911
HP Dana 30 Q's
I have a 06 LJ. I'm wanting to swap in a HP Dana 30. I'm going to be running 35 KM2's. What jeep do I need to get the HP dana 30 out of? I'm wanting to get one that will bolt right in. I know most of the ones in the cherokee's came with 3.55 gear. Did they make them with 3.73 or 4.11 from the factory? Any info would be very much appreciated!
justntime911 is offline
post #2 of 3 Old 10-02-2012, 06:31 AM
mdm
Farm Wheeler
All XJ front axles will bolt into a TJ with no modifications. '96 - '99 XJ are the best years to look for. They don't have the shaft disconnect and do have the same knuckles and u-joints your '04 has. Prior to '96 they had the smaller u-uoints but you can use your current shafts. Go back a few more years and you get into things like the shaft disconnect and a two piece knuckle. They did come with 3.55, 3.73, and 4.10 gears.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 3 Old 10-02-2012, 01:05 PM Thread Starter
justntime911
Thanks for the info mdm!
1984 cj7 come with dana 35 front axle or just dana 30 Littcj7 Engines & Drivetrain 3 09-27-2011 11:11 PM
Swapping a dana 20 transfer case for a dana 18 masimpson48 Engines & Drivetrain 2 12-12-2009 04:05 PM
DANA 30 outers on DANA 44 front axle-- with a twist IN8LYJP Engines & Drivetrain 1 07-08-2009 05:40 AM
Dana 60 axles in Dana 44 housing external hubs dustydoggy Engines & Drivetrain 1 03-26-2009 01:39 AM
Bolt in Dana 44 or Dana 60 Rear Assy - Looking for a dealer wheelinjames Engines & Drivetrain 18 09-23-2006 07:02 PM
