Hp dana 30 : How much higher? - JeepForum.com
post #1 of 8 Old 03-17-2013, 10:39 AM Thread Starter
HAYSHAKER170
I am considering a HP Dana 30 from ECGS. Did a lot of searching but did not see an answer. How much higher is a High Pinion Dana 30 over the Low Pinion Dana 30? And does this translate into a higher diff bottom?
HAYSHAKER170 is offline
post #2 of 8 Old 03-17-2013, 10:50 AM
biffgnar
biffgnar's Avatar
If there is any difference in the clearance at the bottom of the diff it is minimal. It is driveshaft clearance where you pick up a several inches given the pinion being at the top of the diff rather than the bottom.
biffgnar is offline
post #3 of 8 Old 03-17-2013, 10:55 AM Thread Starter
HAYSHAKER170
Which should help with driveshaft angles on a lifted vehicle right?
post #4 of 8 Old 03-17-2013, 12:57 PM
rchase559
The pinion center line is 2.25 inches higher on a HP30 than a LP30.
The higher the pinion, the less severe of a driveshaft angle.
rchase559 is offline
post #5 of 8 Old 03-20-2013, 06:48 PM Thread Starter
HAYSHAKER170
Well, I blew my Jeep wad today. Ordered the HP Dana 30 and 8.8 from ECGS today. Can't wait.
post #6 of 8 Old 03-22-2013, 01:48 PM
freeskier93
Are you sure it's HP? I didn't know ECGS was selling HP 30s, only LP 30s.
freeskier93 is offline
post #7 of 8 Old 03-22-2013, 02:13 PM
biffgnar
biffgnar's Avatar
I have an HP30 that they built. I didn't buy it from them directly, but I have a copy of the invoice. IIRC it was purchased from them a couple years ago so doesn't seem like something new.
biffgnar is offline
post #8 of 8 Old 03-22-2013, 02:19 PM Thread Starter
HAYSHAKER170
Yes it's definitely the HP.
