how to pass emissions with a 86 jeep wagoneer - JeepForum.com
post #1 of 3 Old 02-16-2002, 03:33 PM Thread Starter
shanekidwell
I have an 86 wagoneer and it won't pass emissions, the CO% is to high any suggestions or how can I lower the idle.
shanekidwell is offline
post #2 of 3 Old 02-16-2002, 05:19 PM
evilpsych
evilpsych's Avatar
try changing the oil right before you do the test, the clean oil will pretty much absorb all the bad stuff for awhile at least until after the test. I saw this on a site someplace and a friend of mine did it and it worked pretty well. lemme know how it works, supposedly an EPA guy first mentioned it as a way to beat the smog tester..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 3 Old 03-31-2002, 11:01 PM
81cj
Also a cheap quick fix is get two cans of seafoam,I get it at Napa. Dump one in the tank and using a squirt bottle- my own method- spray it directly into the intake with the filter off. Run the engine and do what they say on the can. It has gotten me to pass on several cars that fail the first time thru. Also sometimes coils may be getting weak, a new coil or a higher voltage coil can lower the emissions just enough. Also, get it HOT before you take it in. 81cj
1981 cj looking to do fun stuff with the cj and my kids.
81cj is offline
1969 Jeep wagoneer axles azurehowl Engines & Drivetrain 2 02-20-2007 11:52 AM
Inline 6 from a Jeep Grand Wagoneer Truggy Engines & Drivetrain 4 02-27-2006 06:17 PM
Carb Swap/Pass Emissions severetitan Engines & Drivetrain 6 06-27-2003 08:15 AM
Emissions By-pass mike mcgovern Engines & Drivetrain 0 02-15-2002 12:12 PM
Gotta pass emissions with the Ram... help? horatio102 Engines & Drivetrain 5 01-19-2002 01:36 AM
