How Much $$$ to Have Head Reconditioned? - JeepForum.com
post #1 of 3 Old 07-28-2005, 06:39 PM Thread Starter
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
I'm thinking about swapping a 4.0L cylinder head onto my 4.2 and was wondering if anyone in here knows about how much it would cost to have a machine shop recondition/rebuild a junkyard inline-6 cylinder head.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #2 of 3 Old 07-29-2005, 05:03 PM
Traveller
I've had a basic valve job done for $125, it included hot tanking, freeze plug replacement, valve and valve seat machining, new valve seals, testing valve spring pressure, and machining the surface to make sure it was flat.
If the valve guides require knurling or replacement there is an additional charge.
If you want it done cheaper, and help some students along the way, a high school auto shop will perform a valve job for almost nothing ($5 per head, plus parts when I was a student). My class used to do them frequently. Turnaround time isn't as fast as a pro shop, but the work is inspected by the teacher before being let go.
Traveller is offline
post #3 of 3 Old 07-30-2005, 02:09 PM Thread Starter
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
I know my local high school has an auto shop class... maybe i'll look into that.
1998 TJ - Can I swap out the OEM Head Unit for a later model head unit? Koko Audio, CB & Ham Radios, GPS, & Electrical 6 02-04-2010 01:01 AM
258 modified head vs. 4.0 head tryn2rest Engines & Drivetrain 1 05-24-2009 04:41 PM
4.0 head gasket, junk yard head or get mine tanked and decked iamdurkee Engines & Drivetrain 1 11-02-2008 12:12 AM
Reconditioned M/T Classic Lock Wheels *PICS* 0IIIII0 Tires & Wheels 6 05-04-2007 09:10 AM
