How many quarts??? - JeepForum.com
post #1 of 3 Old 10-24-2011, 03:22 PM Thread Starter
jmiles8701
How many quarts???
M pulling my pan and changing the tranny filter on my 99' 2.5L with the 3 speed auto. (30rh I believe) how many quarts of ATF+4 do I need???? I'm not doing a full flush, just pulling the pan to change the filter an that's it... Also, to fill the tranny back up, do I just poor it in the dip stick hole?
jmiles8701 is offline
post #2 of 3 Old 10-24-2011, 09:57 PM
jnicewan
Trans total capacity is around 8qts dry, expect to need 5qts if dropping the pan and replacing the filter, you may only need around 4qts or a little more though. Add fluid through dipstick tube and check fluid level in neutral position.
jnicewan is offline
post #3 of 3 Old 10-25-2011, 06:31 AM Thread Starter
jmiles8701
Awesome! Thank you very much!
