How long to wear out a distributor? - JeepForum.com
post #1 of 4 Old 02-04-2006, 01:26 AM Thread Starter
ak-rider
Hi all- FNG here.
I've got ~185K miles on my 97 TJ 4.0L. I'm the original owner, I do all my own maintenance on a regular basis, and up till now I've have had little to no engine problems thus far.
Recently I started getting some rough running when accellerating after a cold start. And the check engine light came on (for the first time ever) a couple of times (code 43). I thought I would start the diagnostics with a fresh tune up, but when I was changing out the cap and rotor I noticed some play in the distributor shaft that I had never noticed before. It easily wiggles in all directions (including up and down) at least an eighth of an inch, maybe more. Like I said, I've never noticed this before.
Does it sound like the distributor is worn out?
Anybody know how much "wiggle" there should be?
Anybody know where I can get a new one?
Thanks for the help guys.
ak-rider is offline
post #2 of 4 Old 02-04-2006, 01:07 PM
bobjp
It sounds like it is worn out. Mine goes up and down a very small amount, but not side to side. I wouldn't buy a new one, I would try to find one at a junkyard. They are easy to take out.
bobjp is offline
post #3 of 4 Old 02-04-2006, 02:12 PM
JoBo
I had a worn out one on a 96 xj 4.0L and I was going to rebush the housing. I took it appart and found it was the shaft was worn, not the housing. Autozone $54 exchange as I recall.
JoBo
Columbus, Ohio USA
2006 KJ CRD Atlantic Blue Pearl Coat Limited
2000 Cherokee Classic with factory 16" wheels
JoBo is offline
post #4 of 4 Old 02-04-2006, 02:17 PM Thread Starter
ak-rider
Thanks for the confirmation guys. Guess it's time to get a new one.
ak-rider is offline
BFG MT KM wear? (long) Grimmjpr Tires & Wheels 9 01-29-2006 01:03 AM
tire wear bently Tires & Wheels 11 12-20-2005 09:15 PM
wear bar? gwarusee Tires & Wheels 3 04-27-2005 03:54 PM
MT/R wear? JNC995 Tires & Wheels 14 04-13-2004 02:35 PM
Long wear Mudders? KYgreenYJ Tires & Wheels 8 10-14-2002 04:54 PM
