Quantcast How hard to pry to remove dana 60 powerlok - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > How hard to pry to remove dana 60 powerlok
TJ 5.25" Speaker Adapters - NalinMFGTruck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 11-17-2009, 07:05 PM   #1
mowjoecj
1976 CJ7
the two axle shafts slid out beautifully. but i can't for the life of me remove the power lok carrier. i need to remove it to turn the cross shaft around. any hints. and i want to try and do it without messing up the shims. help!
mowjoecj is offline   Reply With Quote
Old 11-17-2009, 10:00 PM   #2
CJ8Ted
1985 CJ8
Mark caps, loosen them up but don't take them off. Pry at will, the caps will keep it from comming out all at once. You can also try turning the pinion to "walk" the ring gear away from the pinion. Heat can be your friend when you put it back together (without a case spreader) with this much carrier preload.
Ted
1985 CJ8 on 33s W/ 4.56s
CJ8Ted is offline   Reply With Quote
Old 11-17-2009, 10:49 PM   #3
jeepdaddy2000
1971 CJ5
Use a large flat tipped prybar under one of the ring gear bolts. You may have to slip a block of wood under it. Lean hard.
Oh, and be sure to mark the Powr Lok halves prior to dis-assembly.
jeepdaddy2000 is offline   Reply With Quote
Old 11-18-2009, 06:03 AM   #4
Bgut
2009 JK Wrangler
Having no spreader, my son and I used a tie down strap and a pry bar. Rap the strap around it and the pry bar few times, then just leverage it out. We were surprised how quickly the carrier came out. No need to ratchet it in either just twist it a few times and hold the strap with your hands.
Bgut is offline   Reply With Quote
Old 11-18-2009, 06:37 AM   #5
1998zj
I like to put a wrench on one of the ring gear bolts, butt it against the case and then turn the pinion and it will push the carrier out.
"Our lady of blessed acceleration don't fail me now"
1998zj is online now   Reply With Quote
Old 11-19-2009, 05:29 PM   #6
mowjoecj
1976 CJ7
Thanks for the input. I am a fireman and can't access the forum at work, so I am gonna try and remove in a minute, let you know how it goes!
Old 11-19-2009, 05:55 PM   #7
mowjoecj
1976 CJ7
1998ZJ your way popped it free and jeepdaddy i used the pry method to get it out. awesome guys. one more thing, if i don't remove the bearings from the carrier, or the pinion from the case, backlash and depth shouldn't change when i put it back together, would it? thanks for your help again
Old 11-20-2009, 06:16 PM   #8
CJ8Ted
1985 CJ8
Nothing should change. I would check the backlash or at leased run a pattern.
Ted
Old 11-21-2009, 09:42 AM   #9
mowjoecj
1976 CJ7
will do. I am gonna take pictures as i go. i should hav eit done today
Old 11-21-2009, 01:22 PM   #10
mowjoecj
1976 CJ7
ok guys. one of the cross shafts is broken. Probably cause of the backwards installation. any one have one? any ideas where to get one?
Glock Forum
