How do you do a high pinion set up? - JeepForum.com
post #1 of 2 Old 10-12-2008, 10:53 PM Thread Starter
Jenyus425
I am getting a dana 44 or dana 60 for the front end of my xj. i was wondering how involved of a process it is to do a high pinion set up? do i need to get reverse gears or something? i need to regear it to 4.56 anyways. I'm just curious as to everything that is involved with it.
thanks
Jenyus425 is offline
post #2 of 2 Old 10-13-2008, 07:43 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
i high pinion axle has to be created as a high pinion axle. you cant convert a low pinion to a high pinion, unless you have something that has a removable 3rd member like a ford 9"
you'll need to scavenge for a used high pinions for up front out of older trucks and convert them or get one from SOLID, Dyna Trac or Currie.
the difference between a low pinion and the high pinion is purely at the differential. the pinion is obviously at the top of the diff instead of the bottom. the only change inside is the fact that it uses Reverse Cut gears.
thats pretty much it.
My builds:
and
or follow us on
spyder6 is offline
Pinion high spot stan608 Engines & Drivetrain 2 09-06-2009 07:33 PM
Are all high pinion D-30's the same? 93YJfalcon Engines & Drivetrain 2 04-17-2007 09:20 PM
Dana 60 High Pinion jackedupyj Engines & Drivetrain 3 08-25-2006 10:17 AM
High Pinion d30 - why so much stronger then lp? red99tj Engines & Drivetrain 6 02-28-2006 08:20 PM
What is a High Pinion Axle? topfuel83 Engines & Drivetrain 12 02-17-2006 01:23 PM
