How do my plugs look? - JeepForum.com
post #1 of 9 Old 09-15-2013, 04:16 PM Thread Starter
ridler3d
Do these look lean to you? 258 l6.
1bbl carb
HEI ignition
Autolite 66 plugs.
[IMG][/IMG]
ridler3d is offline
post #2 of 9 Old 09-15-2013, 04:20 PM
wtfcrunch
It might be the angle but the gapping looks pretty short than recommend but other than that they don't seem real real bad. Maybe a little lean wear showing on a few
-_________________-
Tyler Laros
San Diego, CA
wtfcrunch is offline
post #3 of 9 Old 09-15-2013, 04:24 PM Thread Starter
ridler3d
yea just the angle...gaps are .32"
ridler3d is offline
post #4 of 9 Old 09-15-2013, 06:59 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Check this out:
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #5 of 9 Old 09-15-2013, 07:16 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I agree. I do a lot of HEI/Weber conversions on 258s at my Jeep-only shop, and I typically use Autolite 985 plugs gapped at 0.050" for HEI applications.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 9 Old 09-16-2013, 06:41 AM
vadslram
1 and 3 (from the top) look a little crusty but not bad.
Which way did they come out? top forward or top rear?
Agree on the tight gap too. If you got HEI it doesn't make sense not to take advantage of the extra juice.
vadslram is offline
post #7 of 9 Old 09-17-2013, 02:20 PM Thread Starter
ridler3d
top forward.
Ive always used autolite 66 because that's what was in it when I first got the car. Should I be using 985's?
I'll give the .050" a shot and maybe compare with .045", see what runs best. What is the advantage of the larger gap? Bigger spark=more complete burn, correct?
ridler3d is offline
post #8 of 9 Old 09-17-2013, 07:38 PM Thread Starter
ridler3d
just gapped my plugs with a dime (.45") runs much better. thx.
ridler3d is offline
post #9 of 9 Old 09-18-2013, 06:47 AM
vadslram
HAHA serious shade tree.
I haven't done the dime since I used a matchbook to set the points.
vadslram is offline
