How can i get better MPG and power out of my Jeep - JeepForum.com
post #1 of 14 Old 12-10-2001, 05:44 PM Thread Starter
Junior2
I have a 2.5 litre in my jeep and i want better gas milage and more power. If you have any suggestions please tell me. I have tried amny things but nothing seems to work.
Junior2 is offline
post #2 of 14 Old 12-10-2001, 10:03 PM
igofshn
Locked @ both ends
igofshn's Avatar
There is nothing you can do that will realy work except selling it and getting a 4.0. What do you expect from a 4 banger? What size tires do you run? If they are too tall they will kill what little power you have.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #3 of 14 Old 12-10-2001, 10:23 PM
igofshn
Locked @ both ends
igofshn's Avatar
What year is your Jeep. If it is fuel injected then you can try a 4.0 throttle body. This might gve a little extra power. But don't expect miracles. I have heard of a lot of people doing this.
igofshn is offline
post #4 of 14 Old 12-11-2001, 12:14 AM
RockJeep
Motobilt.com
RockJeep's Avatar
I believe mileage and power are oxymorons. lighten the jeep up that might help! hehe
good luck,
bob
1998 Jeep TJ on 37's, locked, long armed etc
Sales Manager at
RockJeep is offline
post #5 of 14 Old 12-11-2001, 01:08 PM
eltj
Add one or two more gerbells.
eltj is offline
post #6 of 14 Old 12-11-2001, 02:41 PM
ArbLockerBoy
There are tons of things you can do but the most significant impact would be injecting the engine. Holly projection is great but somewhat expensive. I think $700. the 4 banger is a good off road engine unless your running really large tires. but the gears can offset the effect of the lagre tires.
if you are going to start throwing money around, I would suggest you buy a different engine
ARB Locking, OME Flexing, 6.32 creeping 79 CJ5
http://www.2trackmindoffroadclub.rockcrawler.com/
ArbLockerBoy is offline
post #7 of 14 Old 12-11-2001, 04:44 PM Thread Starter
Junior2
THe year of the jeep is an '84 and i am only running 215/75R15 as tires. and if anyone knows i'd like to know the gear ratio also
Junior2 is offline
post #8 of 14 Old 12-11-2001, 05:04 PM
Darko
It might just be me, but I can't stand the 2.5 L If I ever had one I would light it on fire and dance around it like a Indian. Get a 258, best engine ever made.
Found a 85 CJ7 tub in good shape with
minimal rust. The resto continues....
Darko is offline
post #9 of 14 Old 12-11-2001, 07:26 PM
hamyscj
The gear ratio should be on the tag on the front diff. If it's not, usually the 5 speeds were 4.10 and the 4 speeds were 3.55. Darko is right, swap in a bigger motor if you want more power. I would suggest a 4.0 but that's my opinion. Hamy.
One Way Up Racing
Romans 10:9
hamyscj is offline
post #10 of 14 Old 01-18-2002, 07:41 AM
Guy Hollister
Jp Magazine just did an article on how to increase the mpg for Jeeps... the top of the list mod for your $ was a block of wood and a zip tie.
Go for it.
Guy
Git a 258.
1984 RHD CJ7
1979 LHD CJ5
Guy Hollister is offline
post #11 of 14 Old 01-18-2002, 08:55 AM
bcompton
bcompton's Avatar
good luck,
bob
I don't agree. Making an engine burn fuel more efficiently will increase both. Just compare a modern high-tech engine with an older one - better in both regards!
01 Sport, front drum brake & birfield joint conversion, custom '4 Wheel Drive' stickers, neon washer nozzles, chrome type 'r' oil pan bolts, wooden bead seat pads, racing exhaust tip, offroad license plate frame,
lots of misc. stuff (2.5" Skyjacker springs, 1" BL, 1"MML, Custom flat tcase & engine skid, RE arms, Skyjacker shocks, JKS Discos, Superlift Trac bars, Garvin bumpers, Warn 9.5ti, Lockright & trac-lock, 32" BFG KM's, Kilby & warn skids, EOR rocker bars, cowl snorkel)
bcompton is offline
post #12 of 14 Old 01-18-2002, 10:18 AM
rivertrout10
rivertrout10's Avatar
Darko - if this is the case why are you looking to put a Ford 302 in your Jeep? Do you think before you post?
Derek
Jeep - its a job - not an adventure
rivertrout10 is offline
post #13 of 14 Old 01-27-2002, 12:32 AM
JIM79CJ7
JIM79CJ7's Avatar
originally posted by Mikeythefireman :
Mr. Bill, you're a Jacka$$! or should I say 'drack you're a Jacka$$ I was looking for a straight answer there.
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
1979 CJ7 / 304 /T 150 /HUGGER ORANGE PAINT JOB/ Lots of cool stuff
2003 Inca Gold Rubicon , <------ Sissy jeep :)
JIM79CJ7 is offline
post #14 of 14 Old 01-27-2002, 09:00 PM
I-4
I-4's Avatar
i do have a 4 cylinder.it's not bad for crawling or other slow type adventures;but on the flip side it is not the fastest thing around on the highway.try a less restrictive intake(you will probably have to build it yourself)is the carb in good shape?an free flow type exhaust will help.you could also try a cam,but it might not be emmisions legal(don't know if you have that pita there or not)it's a four cylinder,it's not the fastest thing out there,but when was the last time you ever saw someone(that is sane) trying to fly over an obstacle?our sport is about slow and easy.i can go everywhere the guys with large horsepower can go and be lighter and easier to pull out when i get stuck.one more benefit of having a 4,more gas in your tank and you don't have to swap out your entire drive train to go have some fun.this is merely my opinion.hth
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
Jeep TJ getting no power and no acceleration enzosf General Jeep & Off-Road Equipment 1 10-18-2009 03:49 PM
1996 jeep cherokee windshield wipers, ac, stereo lost power scubasteve21 Audio, CB & Ham Radios, GPS, & Electrical 0 07-15-2009 04:19 PM
My jeep has no power.....Help! mufan Engines & Drivetrain 2 07-28-2008 05:34 AM
The Jeep I6 Power Manual EricsXJ Street Jeep Forum 0 06-07-2006 10:53 PM
power windows, where to hook 12v to where it only works when jeep is on? TXjeepTJ Audio, CB & Ham Radios, GPS, & Electrical 12 05-24-2006 03:53 PM
