Horrible Misfire Now No start - JeepForum.com
post #1 of 8 Old 10-23-2011, 05:32 PM Thread Starter
Noahkk24
1990 XJ Cherokee
Was on the highway and noticed the car jolt for a second when I tried to accelerate. Tried again & same result. I immediately get the car off the highway (Luckily I'm close to home) and take the street way. I notice that when at idle there is almost no real sign of any problems or serious misfiring.
However, when I gave the car gas whether in drive or neutral there was serious misfiring once the car got to 1500rpm+ and it would not let the motor rev much past that at all. Was able to limp home and now, of course the car wont start. It will crank all day but just won't turn over...Help would be appreciated as I have NO clue where to start!!
Noahkk24 is offline
post #2 of 8 Old 10-24-2011, 11:53 AM
Danny0717
What motor n type of jeep? Not sure if u have heard about the famous pcm problem.
Danny0717 is offline
post #3 of 8 Old 10-24-2011, 03:03 PM Thread Starter
Noahkk24
1990 XJ Cherokee
4.0 Liter...Just changed the CPS
Noahkk24 is offline
post #4 of 8 Old 10-24-2011, 04:05 PM Thread Starter
Noahkk24
1990 XJ Cherokee
OK, so I resat the plugs on the distributor cap and moved the CPS a bit (The top bolt I used to replace does not fit in perfectly, I have the correct bolt so I'll put that in later on) BUT, it started so my problem has been narrowed down to 2 possibilities. Either the distributor cap is going bad or the CPS is not grounded well...
Either way it goes, the idle is still pretty rough but not horrible like it was...hmmmm
Noahkk24 is offline
post #5 of 8 Old 10-24-2011, 08:25 PM
Danny0717
I'm sure you did ur homework. But r u positive the firing order is correct too? Also is clean that throttle body up nice. And clean where those sensors sit by it. Mine was rough n black n I cleaned mine up nice and it leveled out nice. U have any check engine lights on?
post #6 of 8 Old 10-24-2011, 08:42 PM
Boodyrider
check distributor shaft for play. There should be little or no wobble. bad wobble means new distributor time.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #7 of 8 Old 10-25-2011, 02:32 AM Thread Starter
Noahkk24
1990 XJ Cherokee
The firiing order was actually wayyyyy off...I got that straightened out, I got it running but decided against driving it until I clean up the few other side issues there obviously are. Thanks for the help guys!
Noahkk24 is offline
post #8 of 8 Old 10-25-2011, 06:05 AM
Danny0717
Glad I could help.
3.7L horrible gas milage ifelovr Engines & Drivetrain 1 04-14-2012 10:17 PM
4.0 cold start misfire resolved???? tubbednova Engines & Drivetrain 0 01-06-2011 10:25 AM
My wheels look horrible ..... iceman1947 Tires & Wheels 3 08-30-2010 10:49 AM
horrible hillbilly fab funshootin1 Fabrication Shop 10 08-25-2009 11:11 AM
Random 4.0 Cold-Start Misfire peeweeXJ Engines & Drivetrain 2 05-10-2009 11:04 PM
