Holley carb and engine assistance - JeepForum.com
post #1 of 2 Old 05-10-2014, 04:48 PM Thread Starter
ukenout
1979 CJ5
Hello folks, been awhile since i've been on. Been having an issue getting my 79 CJ5 with 258 , 4.0 Head swap to run right. I added an Offy 4 barrel intake as well as put on a Holley 470 TA carb along with a 4 barrel carb spacer to get it properly mounted as the linkages would allow for a flush mount. It has the 57 jets in there right now and the power valve was replaced to the correct pv as I was drawing 22 pounds of vacuum. My issues are the carb seems to always run rich and the exhaust has a strong fuel smell, so much it gets into my clothes when I drive it. I've opened the gap up on some fresh spark plugs last weekend to .045. I have also done the Team Rush upgrade in the past.
I'm wondering if the carb is just to much carb and I should have gone with a 390cfm. One thing I did do with the carb was add the non adjustable fuel bowls to it that way I wouldn't have to fiddle with it. Seems though i'm fiddling with it way to much!!!!
Any suggestions will greatly be appreciated.
ukenout is offline
post #2 of 2 Old 05-11-2014, 09:31 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Rich at idle? readjust the idle mixture. Check to see if the power valve is leaking.
Rich under cruise? try a smaller jet
Rich under acceleration (secondaries closed)? smaller power valve. Secondaries open, smaller secondary jets
If your smelling exhaust on your clothes while your driving, YOU MUST RE-ROUTE YOUR EXHAUST
jeepdaddy2000 is offline
