Hole in transfer case - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Hole in transfer case
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 06-20-2014, 11:12 AM   #1
akagrifty
Ok so I was taking my AX15 trans out to get over to my buddy to rebuild. The trans came out no problem with the transfer case still attached. So then I went to take the transfer case off the trans and ran in to a problem, it wouldn't come apart. I talked to my buddy and he said to use a chisel. Well I put the chisel through the transfer case. So now there is a hole where the transfer case bolts to the transmission. I have someone who says then can weld it but they told me they weren't sure if it needed to be welded. Does anyone know if this needs to be welded? Also the transfer case is still attached to the trans is there any suggestions to remove it with out doing anymore damage?
akagrifty is offline   Reply With Quote Quick reply to this message
