Hole in transfer case - JeepForum.com
post #1 of 6 Old 06-20-2014, 11:01 AM Thread Starter
akagrifty
Ok so I was taking my AX15 trans out to get over to my buddy to rebuild. The trans came out no problem with the transfer case still attached. So then I went to take the transfer case off the trans and ran in to a problem, it wouldn't come apart. I talked to my buddy and he said to use a chisel. Well I put the chisel through the transfer case. So now there is a hole where the transfer case bolts to the transmission. I have someone who says then can weld it but they told me they weren't sure if it needed to be welded. Does anyone know if this needs to be welded? Also the transfer case is still attached to the trans is there any suggestions to remove it with out doing anymore damage?
akagrifty is offline
post #2 of 6 Old 06-20-2014, 11:11 AM
napaguy
A picture or two would be helpful here..a chisel was definately not the correct tool for the job Im guessing you know that by now.
napaguy is offline
post #3 of 6 Old 06-20-2014, 11:11 AM
MurdaJs
Got any pics?
Maybe someone else who knows for sure will chime in, but in my 5 speed (nv3500) the transmission is not sealed by the tcase. In the 44re automatic, the t case input shaft mates with the trans to create a seal
MurdaJs is offline
post #4 of 6 Old 06-20-2014, 11:12 AM
MurdaJs
As far as removing the tcase, have you tried supporting the weight of the tcase with a jack and then sliding it out? They're pretty heavy mofos
MurdaJs is offline
post #5 of 6 Old 06-20-2014, 11:36 AM Thread Starter
akagrifty
Yeah I now know that at the very least I used the chisel the wrong way. When I get home in a little while I will take some pictures and put them up. The trans and transfer case are out of the jeep sitting on the garage floor so a jack stand wouldn't be very helpful.
post #6 of 6 Old 06-20-2014, 03:51 PM Thread Starter
akagrifty
There is the hole still can't get this thing apart I know it shouldn't be this hard I have all 6 bolts out
