hole in oil pan - JeepForum.com
post #1 of 12 Old 03-21-2004, 09:19 PM Thread Starter
jugger
hole in oil pan
I recently took my jeep off the road while it was icy out. I hit a rock and there is a inch long hole in the oil pan. I was going to take off the oil pan and weld it back together. But my dad wants to just reweld it when its still on the car.( its a b**tch to take it off) This sounds kind of hard to me, see as its near all this oil residue, has anyone ever had this problem? any suggestions?
jugger is offline
post #2 of 12 Old 03-22-2004, 10:08 AM
DanB
I guess if you get it clean enough you could weld it.
Just remember oil burns.
DanB is offline
post #3 of 12 Old 03-22-2004, 11:07 AM
BamaJeeper
BamaJeeper's Avatar
It's a B**** to remove??
Just imagine if it were a Honda oil pan and then it seems REALLY easy.
Remove it, clean it, remove paint from weld area, clean again, and weld it.
Should only take two hours.
Out of the darkness comes light.
BamaJeeper is offline
post #4 of 12 Old 03-22-2004, 06:09 PM
yj_magnus
yj_magnus's Avatar
I thought that once.........................once.
I have a 91' with 154,000 miles on it, and I don't think my pan had ever been off. About 15 minutes to get all the bolts out......then 1.5 hours to pry the pan off the block......then another 4 hours cleaning the old gasket off the pan and the block (maybe a dremil would have helped)(and safety glasses!!)......half an hour flattening out the bends where I was prying.......anther half an hour to put it back together. So with a lunch break and a couple trips to the bathroom, I wasted almost 8 hours of my day.
Drain it, degrease it, and weld it where it is!!!
See, its like my grandaddy use to alway say "When hell is full, the dead will walk the earth"
yj_magnus is offline
post #5 of 12 Old 03-24-2004, 06:15 AM
BamaJeeper
BamaJeeper's Avatar
4 hours to remove the gasket? Must not have been the factory one-piece gasket but a Felpro crappy three-piece gasket.
post #6 of 12 Old 03-24-2004, 03:43 PM
yj_magnus
yj_magnus's Avatar
By the time I got it off, there was no way to tell what it had been. It was nothing but crumbs.
post #7 of 12 Old 03-25-2004, 02:08 PM Thread Starter
jugger
The problem i had is the fact that the brake line, along with some other stuff under there, crossed over the pan in a few different spots. in order to take the pan off i would have to take all this other sh*t off. not really worth the time.
jugger is offline
post #8 of 12 Old 03-25-2004, 02:24 PM
yj_magnus
yj_magnus's Avatar
Wow, thats kinda weird. Theres nothing under my oil pan but a mud shield and the axle. My brake lines run around the front of the frame and along below the radiator. (not the back ones ) What year is your rig?
post #9 of 12 Old 03-25-2004, 09:20 PM
BlackWhyJay
BlackWhyJay's Avatar
I tore a hole in mine then proceeded to bring it to my friend's house and he welded it while i stood there, took 10 minutes.
THIS IS NOT A SMART IDEA!!!!
It worked like a charm tho.
Chris
AIM: BlackWhyJay
Email:
90 Lifted and locked YJ
BlackWhyJay is offline
post #10 of 12 Old 03-30-2004, 01:07 PM
n1ywb
n1ywb's Avatar
JB Weld.
20 characters.
n1ywb is offline
post #11 of 12 Old 04-03-2004, 07:25 PM
EvilJackBall
Use a dremel with a sanding bit and go real lightly on the old gasket (so you don't eat up the pan) should take the gasket off in about 15 minutes.
EvilJackBall is offline
post #12 of 12 Old 04-14-2004, 10:20 AM
jeepsonly
IF you decide to remove it, plan to replace the rear main seal at the same time. It's right there anyway and eventually you'll need to replace it anyway, depending on the age. I paid someone to replace my oil pan and rear main seal and it cost me $120 for labor. I'm one of those people that would have needed 8-40 hours to do the same job :-)
Bill Hooven
Jeeps Only - A Yahoo-style directory for Jeep enthusiasts
jeepsonly is offline
Wouldn't this be a fun MS Hole contender? howellru General Jeep & Off-Road Equipment 3 10-02-2008 01:54 PM
Cut a hole...What next rxl General Jeep & Off-Road Equipment 0 07-21-2007 09:03 AM
Hole? hawaii Engines & Drivetrain 7 12-03-2006 01:12 PM
where is a hole in the firewall tjbrotha Audio, CB & Ham Radios, GPS, & Electrical 6 08-18-2006 11:43 PM
Best sub for cubby hole? Roodki Audio, CB & Ham Radios, GPS, & Electrical 25 10-04-2005 11:06 AM
