Hole in engine block under valve cover. - JeepForum.com
post #1 of 3 Old 04-09-2013, 03:35 PM Thread Starter
CZ_Kid
I'm getting back into doing some work on my 86 cj7 (inline 6) that I've been away from for some time now. Well among other things, I've decided to replace the valve cover and gasket. After removing valve cover I noticed there is a threaded hole through the engine block and I can see coolant pooling. This hole is fwd the block on the driver side under the gasket. Is the a problem? I have noticed some compression issues but haven't put much thought or time into this. If this hole is a problem, can it be plugged and if so what would be some plug options. Thanks for the help.
CZ_Kid is offline
post #2 of 3 Old 04-09-2013, 07:17 PM
78FordF150
1983 CJ7
You want to post this in the CJ forum for more responses. Sorry but I can't help much with this problem.
Measure with a Micrometer
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install
78FordF150 is offline
post #3 of 3 Old 04-09-2013, 08:46 PM Thread Starter
CZ_Kid
Thank you partner, I didn't see that thread. I just posted as well as my other thread.
CZ_Kid is offline
