-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   High rev to start moving from startup?? (http://www.jeepforum.com/forum/f19/high-rev-start-moving-startup-1755378/)
99WJCHRIS 11-03-2013 09:43 PM
Be noticed that when I get in my jeep in the morning and start it I put it in drive or reverse and I have to get the engine up to sometimes 2500 rpm's before the jeep starts to move. It seams to run fine after that but it's just that first move after startup that it's doing it. I'm thinking its cold ATF and after it gets moving and warms up its fine but wanted some other peoples insight on it. What of y'all think? (99 WJ, 4.0, Automatic transmission)
GilaMtnJeep 11-04-2013 07:40 PM
Sounds like "delayed engagement". Revving to 2500 to get it going is not good for your trans. Mine does the same thing. I let it idle for a few minutes before going. If I can't let it idle for a few I'll cycle through the gears a couple times and I can usually go without issue.
holysirsalad 11-04-2013 09:47 PM
When was the fluid last changed?
zjbeater 11-05-2013 10:55 AM
Mine started that way then it slowly started doing it every time I went off the line the trans is burning itself up it is a commen prob with the grand Cherokee
99WJCHRIS 11-07-2013 10:59 AM
Fluid was drained and new fluid and filter put in less than 5k miles ago. It did it before the change. I was hoping the change would fix it. Seems like it's only cold days where it hasn't been run in a few hours or days and everything is cold.
The time now is 04:13 PM.
