High Pinion 30 question - JeepForum.com
post #1 of 6 Old 04-12-2012, 05:45 PM Thread Starter
TexasTeaJ
TexasTeaJ's Avatar
I know you can't use ring and pinion gears from a LP30 for a HP30 but can you flip the carrier around and use the carrier from the LP30?? Sorry if this is a dumb question.
TexasTeaJ is offline
post #2 of 6 Old 04-13-2012, 08:02 AM
mike_dippert
mike_dippert's Avatar
The same ARB locker goes in both...so I'm it will work.
I never tore into the stock diff so I honestly don't know what it looks like without the gears.
mike_dippert is offline
post #3 of 6 Old 04-13-2012, 09:18 PM
sctmcly0
The ring and pinion are to be replaced as a matched set. I if you are just replacing the carrier you should be okay
sctmcly0 is offline
post #4 of 6 Old 04-14-2012, 09:23 AM Thread Starter
TexasTeaJ
TexasTeaJ's Avatar
Right, I just wanted to find out if I could fit my carrier from my LP30 because the HP30 that I found has the carrier for 3.55s and lower. My LP30 is 3.73.
post #5 of 6 Old 04-14-2012, 12:30 PM
ajmorell
ajmorell's Avatar
Yeah, it will work. I used my lp30 carrier in my hp30
ajmorell is offline
post #6 of 6 Old 04-15-2012, 02:50 PM
sctmcly0
I don't think the carrier is the same between a 355 and 373 tho
sctmcly0 is offline
What year of XJ had high pinion d30? Jenyus425 Engines & Drivetrain 0 10-21-2008 08:34 PM
How do you do a high pinion set up? Jenyus425 Engines & Drivetrain 1 10-13-2008 07:43 AM
Are all high pinion D-30's the same? 93YJfalcon Engines & Drivetrain 2 04-17-2007 09:20 PM
Dana 60 High Pinion jackedupyj Engines & Drivetrain 3 08-25-2006 10:17 AM
What is a High Pinion Axle? topfuel83 Engines & Drivetrain 12 02-17-2006 01:23 PM
