-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   High Pinion 30 question (http://www.jeepforum.com/forum/f19/high-pinion-30-question-1355952/)
TexasTeaJ 04-12-2012 04:45 PM
I know you can't use ring and pinion gears from a LP30 for a HP30 but can you flip the carrier around and use the carrier from the LP30?? Sorry if this is a dumb question.
mike_dippert 04-13-2012 07:02 AM
The same ARB locker goes in both...so I'm it will work.
I never tore into the stock diff so I honestly don't know what it looks like without the gears.
sctmcly0 04-13-2012 08:18 PM
The ring and pinion are to be replaced as a matched set. I if you are just replacing the carrier you should be okay
TexasTeaJ 04-14-2012 08:23 AM
Right, I just wanted to find out if I could fit my carrier from my LP30 because the HP30 that I found has the carrier for 3.55s and lower. My LP30 is 3.73.
ajmorell 04-14-2012 11:30 AM
Yeah, it will work. I used my lp30 carrier in my hp30
sctmcly0 04-15-2012 01:50 PM
I don't think the carrier is the same between a 355 and 373 tho
The time now is 02:50 AM.
