High output oil pump assembly? - JeepForum.com
post #1 of 5 Old 03-24-2006, 08:49 PM Thread Starter
PrimerFJ40
Where can I get a good h/o oil pump rebuild kit for a AMC 360?
PrimerFJ40 is offline
post #2 of 5 Old 03-25-2006, 11:26 PM
Traveller
I'm sure you could find one at Summit Racing, or PAW (Performance Automotive Wholesale). They aren't expensive.
Traveller is offline
post #3 of 5 Old 03-26-2006, 11:01 AM
violatedppl
make sure you get high volume not high pressure, I know I guy who mixed em up and blew out all he seals
14 jkur expo and mild wheeler
violatedppl is offline
post #4 of 5 Old 03-26-2006, 05:37 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Another thing to consider if you use a high volume oil pump. Since the oil doesn't stay in the base pan as long you should consider a bigger pan which increases oil volume or an oil cooler.
laybackman is offline
post #5 of 5 Old 03-27-2006, 11:15 AM
401ton
http://www.bulltear.com/catalog/index.php?cPath=21_35
This site has alot of AMC parts and info.
AMC 401, Howell TBI, NP-435, Atlas 4.3, Rockcrusher 60, Shaved 14 bolt, 110" WB, Stazworks Double Beadlocks and 42's...
401ton is offline
4.0 high output - how to tell if I have it? txasylum Engines & Drivetrain 9 11-08-2010 11:31 PM
High output 2.5l ???? gimme_fuel Engines & Drivetrain 5 07-10-2007 04:40 PM
High Output Alt ?'s 4x4punk Audio, CB & Ham Radios, GPS, & Electrical 4 08-26-2004 12:09 PM
4.0-4.0 high output cheesegurl Engines & Drivetrain 3 05-20-2004 06:00 AM
4.0 high output tufmar Engines & Drivetrain 2 03-03-2002 03:02 PM
