High Fuel Pressure - JeepForum.com
post #1 of 3 Old 06-02-2012, 08:31 PM Thread Starter
ga-dawgs
High Fuel Pressure
I have a 1995 Wrangler with a 2.5. My fuel pressure at idle is 60+psi. I assume there is a blockage in the fuel return line, but the line is clear to the tank. I removed the fuel pump and the fuel return dip tube appears to be pressing against the bottom of the tank. There does not appear to be a clear "cup" at the bottom of the tank and the rubber "stopper" is badly degraded. The Jeep has a bad gas smell when I let off the gas pedal. At this point I'm assuming the hard dip tube is being blocked by the plastic tank pressing against it. My thought is to trim the tube....maybe! Any suggestions! Thank you!!
ga-dawgs is offline
post #2 of 3 Old 06-03-2012, 12:48 AM
jnicewan
Fuel pressure should be around 30 psi when running, and 40psi with vacuum disconnected or under heavy load. I would think you would be just fine with trimming the tube since its just return, some people trim an angled cut into the line to prevent the concer that you suspect.
jnicewan is offline
post #3 of 3 Old 06-03-2012, 06:25 PM Thread Starter
ga-dawgs
Thanks for the reply jnicewan! I've got it all back together and seems to have helped the exhaust smell problem. The Jeep also seems to be starting a little quicker!
Thanks again,
Jared
ga-dawgs is offline
high oil pressure C_King Engines & Drivetrain 5 05-29-2012 12:08 AM
99 XJ High oil pressure? PaXJ384 Engines & Drivetrain 4 11-07-2011 05:14 PM
non High Output to High Output fuel pressure ISSUES hifooy07 Engines & Drivetrain 0 05-14-2010 07:52 PM
'89 2.5L Oil Pressure too high, sprays oil everywhere kenmelj Engines & Drivetrain 16 01-10-2009 08:15 AM
high oil pressure sweerik Engines & Drivetrain 14 03-06-2007 11:36 PM
