Quantcast HHO EXPERIENCE posting - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > HHO EXPERIENCE posting
Old 06-03-2008, 07:28 AM   #1
Map40
Content blocked - deleted
Map40 is offline   Reply With Quote
Old 06-03-2008, 07:37 AM   #2
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by Map40 View Post
...The third run, I got 29MPG in half tank.....
Is this estimated or calculated?
Was it a half tank according to the gauge or according to how many gallons it took you to fill it back up?
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 06-03-2008, 10:14 AM   #3
Map40
Old 06-03-2008, 10:24 AM   #4
FLATFENDER54
I dont trust the scanguage for mileage or your odometer readings at all since you dont have the correct speedo gear. I also dont trust the 1/2 tank measuring. You need to run several tanks before you can come to us with your results....................that is after you get the correct speedometer gear. Im not trying be an *** and I really hope you are getting 29 mpg by the way
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEzhttp://i73.photobucket.com/albums/i225/FLATFENDER54/Off%20raod%20trip%20to%20Colorado%20with%20son%20a nd%20dad/DSC01873.jpg
66 Chevelle(Not a good pic in shed 4 many years)http://i73.photobucket.com/albums/i225/FLATFENDER54/memeorystick512262.jpg
93 ford lighting-trick flow heads 6 psi supercharger http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01636.jpg
1954 WILLYS CJ3B (under construction) http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01301.jpg
99 escort zx-2 my favorite lil gas "sipper" (who cares)lol
USMC "Semper Fidelis"
FLATFENDER54 is offline   Reply With Quote
Old 06-03-2008, 10:24 AM   #5
Map40
Old 06-03-2008, 10:27 AM   #6
Map40
Old 06-03-2008, 11:45 AM   #7
COWBOYJEEP
Thanks am now following this thread as well as Kevin R's . Please keep posting . Good luck John
COWBOYJEEP is offline   Reply With Quote
Old 06-05-2008, 09:20 AM   #8
Map40
Old 06-05-2008, 09:29 AM   #9
FLATFENDER54
So on one tank you increased mpg by 40 percent? Or at certain times it increased 40 percent?
Old 06-05-2008, 10:00 AM   #10
Unlimited04
Unlimited04's Avatar
post a picture of your setup.
how many gallons of water do you use per tank of gas?
if you do the stoichiometric equations to run a 4.0L engine fully on H2, with regard to extracting hydrogen from water, you'd need approx. twice the volume of water as you do gasoline to keep a 14.7:1 fuel ratio, but hydrogen requires a ~34:1 ratio
http://www.jeepforum.com/forum/5299384-post149.html
Unlimited04 is offline   Reply With Quote
Old 06-05-2008, 10:10 AM   #11
jgorm
Not quite. When liquid turns to gas it normally expands to about 24x its volume. Also remember that the air fuel ratios that i quoted in your link are for regular air, and not for pure oxygen. For a good scientific test we need to see 3 tanks mpg (include indicated miles, actual miles, and gas volume from the pump) without the HHO, then 3 full tanks while using the HHO. I can analyze the data for statistical significance and if its not significant you would need to run more tanks. My scan gauge can be off by a gallon or 2 on each fillup so you should not use the SG for fuel volume. The miles should be accurate if it was calibrated to the GPS.
jgorm is offline   Reply With Quote
Old 06-05-2008, 10:16 AM   #12
msavard
Bookmarking this one.
More details about the setup and could you post your raw data please?
2004 Yellow TJ Sport
(purchased stock on 6.3.06)
4.0L Auto • 35" Maxxis Bighorns • D30/D44 w 4.88 Gears • 2.5" OME LJ/XJ lift • JKS Trackbars • Brown Dog MML • 1" BL • Warn Engine Skid • Aussie Locker (FR) / Rubi Air Locker (REAR) • SYE/CV • Nth Adj Control Arms • Bestop Oversize Tire Carrier • PSC Rocker Knockers • ORO Swayloc • TNT Tube Fenders
MIDSOUTH JEEP CLUB > Jeepers from TN, AR, MS, and KY
msavard is offline   Reply With Quote
Old 06-06-2008, 07:48 AM   #13
Map40
Old 06-06-2008, 07:56 AM   #14
Unlimited04
For those of you without calculators:
No HHO driving carefully, posted speeds, TPS at 30%
199 miles, 10.2 galons = 19.5 mpg
201 miles, 10.5 galons = 19.1 mpg
198 miles, 10.1 galons = 19.6 mpg
This are unadjusted mullage numbers (as I will keep them that way, it would be good enough for comparison purposes)
With HHO same driving
199 miles, 8.2 galons = 24.2 mpg
200 miles, 7.8 galons= 25.6 mpg
190 miles, 9.2 galons * (I was running out of water in the unit). = 20.6 mpg
Old 06-06-2008, 10:00 AM   #15
Chris_
How are you avoiding throwing a CEL? Are you running EFIE?
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline   Reply With Quote
Glock Forum
