hesitation on hard acceleration - JeepForum.com
post #1 of 8 Old 07-04-2012, 05:22 PM Thread Starter
dhardy1357
1975 CJ5
while the motor is cool and choke is on everything is good. after motor warms up and choke is fully open there is a lot of hesitation when you stomp on the gas. im thinking i may need bigger jets?
its a 304 bored .060 over, rv cam, headers, msd 6a ignition with the motorcraft 2100. any suggestions, i believe the timing is advanced 13-15* IIRC.
-1975 cj5 in the making-
304 rebuilt 3/23/11
.060 over, rv cam
Cdi ignition coming soon.
dhardy1357 is offline
post #2 of 8 Old 07-04-2012, 06:45 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Where is your distributor vacuum advance hose connected to?
cruiser54 is offline
post #3 of 8 Old 07-04-2012, 07:45 PM Thread Starter
dhardy1357
1975 CJ5
its on the brass colored hose barb on the front choke side of the carb
304 rebuilt 3/23/11
.060 over, rv cam
post #4 of 8 Old 07-04-2012, 11:17 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Is that fitting above or below the throttle butterfly?
post #5 of 8 Old 07-05-2012, 09:53 AM Thread Starter
dhardy1357
1975 CJ5
Im not sure where or what the throttle butterfly is
304 rebuilt 3/23/11
.060 over, rv cam
post #6 of 8 Old 07-05-2012, 02:00 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Inside the carb. The metal plate that opens and closes with the accelerater cable movement.
post #7 of 8 Old 07-05-2012, 06:06 PM Thread Starter
dhardy1357
1975 CJ5
Im not their to check right now but I searched on google and its hooked up to where all the pics show
304 rebuilt 3/23/11
.060 over, rv cam
post #8 of 8 Old 07-05-2012, 06:08 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
When you get home, see if there are more than 1 vacuum ports on the carb. If there are, use the one highest up on the carb.
Squeaking under hard acceleration Silvestris Engines & Drivetrain 8 11-07-2010 08:28 PM
Hard start, Hesitation, Bogging from 91 4.0 BoanHed Engines & Drivetrain 2 07-07-2009 10:23 AM
Hesitation on acceleration skocheroni Engines & Drivetrain 16 02-07-2007 05:54 PM
Slight Vibes under Hard Acceleration??? jeepdan Tires & Wheels 5 01-29-2003 08:13 AM
4.0L Hesitation/ Stumble on acceleration Woodtroll Engines & Drivetrain 0 07-29-2002 05:32 PM
