HELP What causing downshifting? - JeepForum.com
post #1 of 5 Old 09-20-2012, 05:04 PM Thread Starter
papadon99
1998 FSJ Cherokee
98 Grand cherokee Laredo, 4.0l engine and auto transmission (42RE)
When going down highway after @ 30miles, will shift down to 3rd and stays there. What could be causing this? Mechanic said Transmission itself is ok. Sensors maybe? Which ones?
HELP!!!
TY ahead of time!!
papadon99 is offline
post #2 of 5 Old 09-20-2012, 06:41 PM Thread Starter
papadon99
1998 FSJ Cherokee
OOps, sorry!
post #3 of 5 Old 09-24-2012, 02:47 AM
seattle_yj
HELP!!!
TY ahead of time!!
The throttle cable might need adjustment. I would start there.
seattle_yj is offline
post #4 of 5 Old 09-24-2012, 10:50 AM
seattle_yj
I was reading through my FSM last night and came across this issue in the diagnostics section. When I get back to my computer I will post that info here.
post #5 of 5 Old 09-24-2012, 10:49 PM
jnicewan
T/V cable adjustment is very important but that shouldnt be an issue for O/D or T/C lock (Torque Converter lock-up).
First off can you verify if its downshifting into 3rd, or is the T/C just unlocking. Also when it happens try hitting the O/D cancel switch a see what happens. If it is in 3rd gear then you should notice the T/C locking in 3rd ( T/C only locks 3rd when O/D is cancelled with the button)
What is probably the heaviest influence in T/C lock up and O/D shifting as far as external trans concerns/sensors is the TP sensor, also if its just T/C lock up problems I would check the brake lamp switch too. If the brake lamp switch is coming on or is real sensitive to come on then it could be unlocking the T/C
jnicewan is offline
Fluid leaking causing smoke? jaelabuen Engines & Drivetrain 2 07-19-2012 02:56 PM
Hard downshifting wfn1999 Engines & Drivetrain 1 05-14-2012 08:53 PM
Fuel Pressure causing misfire? lordChase Engines & Drivetrain 2 01-17-2010 12:03 PM
Front driveline squeak. Not sure what causing it Carolinatj906 Engines & Drivetrain 3 01-11-2010 07:28 AM
Lift kit causing trembling (55-40 mph) JR LeMire Tires & Wheels 0 10-05-2001 02:17 PM
