help! tranny questions - Page 2 - JeepForum.com
post #16 of 18 Old 10-06-2012, 09:24 AM Thread Starter
oldschoolnewcj8
1982 CJ8
sorry if I sound repetitive but does this sound like everything im going to need to purchase: seperator plate, bearing retainer, the nose cone, and the input bearing? also what about the input shaft length, what should I do if it needs to be changed? Im going to hopefully drop the t14 today and check all the mounting holes on the t18 to see if the bellhousings match up.
oldschoolnewcj8 is offline
post #17 of 18 Old 10-06-2012, 06:55 PM
BlueRubiconrich
You have to use the T18 bell housing
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #18 of 18 Old 10-06-2012, 08:33 PM
1986cj
Bearing retainer and nose cone= samething. You need to use the T18 bellhousing as bluerubiconrich said, the t14 is not the same, it is deeper. You can get a clutch kit for a 79 CJ5 with the 258 and a t18. It should fit and was a stock setup with the T18 option. Do a google search as there is a ton of info on this swap. Looking at the pics again you also need the clutch fork.
1986cj is offline
Tranny questions Hpwhitehurst Engines & Drivetrain 3 09-18-2012 10:34 PM
jeep cj tranny and air intake questions oldschoolnewcj8 Engines & Drivetrain 0 09-08-2012 04:06 PM
Tranny Help!!! 1980 CJ7 Tranny Fill? 80Cjbaby Engines & Drivetrain 1 01-04-2010 03:37 PM
Welding the tranny temp sender bung into the auto tranny pan Jerry Bransford Fabrication Shop 10 12-02-2007 08:35 PM
Questions about diff & tranny oil... Carpe Diem General Jeep & Off-Road Equipment 6 03-09-2002 09:44 PM
