Help; spark plug from h***. - JeepForum.com
post #1 of 9 Old 09-04-2013, 12:38 PM Thread Starter
JeeperSC
All of my spark plugs were in insanely tight. The jeep has 40,000 miles and I was replacing the original plugs. The plug on the passenger side all the way in the back seems impossible to get out. I think it's the #1 plug.
I had a swivel joint attached to the spark plug socket. Then about a 13 in
Extension attached to the torque wrench so it extended far enough out of the engine bay so I can get enough leverage to twist. The thing still won't budge. Infact, it broke the new duralast universal joint! The plastic around the spark plug also cracked all up. So now it HAS to come out before its drivable.. Any ideas. I know I could probably use a larger torque wrench.
2008 Wrangler Unlimited-X 4x4
Steel Blue Metallic
JeeperSC is offline
post #2 of 9 Old 09-04-2013, 01:36 PM Thread Starter
JeeperSC
My failed system...
Steel Blue Metallic
JeeperSC is offline
post #3 of 9 Old 09-04-2013, 02:13 PM
jnicewan
That's a pretty steep angle for the swivel joint, the higher the angle the more you will have binding and the joint will flex/break. Im not familiar with the JK's enough to know if you can access the plugs through the inner fender or from underneath but you might try that. The less extensions, and straighter you can get your setup then the easier it will come out. Since the plug is broken you might be able to use a regular socket to get the broken plug out if it helps.
jnicewan is offline
post #4 of 9 Old 09-04-2013, 02:45 PM
JeeperCreepers7
Have you tried jacking up the engine on that side and going in from underneath?
JeeperCreepers7 is offline
post #5 of 9 Old 09-04-2013, 02:52 PM
wtfcrunch
Yeah its the angle you are coming from although it seems the only way you need to get a better angle on the plug. All that torque you are applying isn't hitting the spot
-_________________-
Tyler Laros
San Diego, CA
wtfcrunch is offline
post #6 of 9 Old 09-05-2013, 10:02 AM
Pierre_r
1989 XJ Cherokee
It looks like you have to remove the battery to get a better angle.
The problem you have is that the extension you have on steals all the torque you are using on the handle.
The extension,s always twist alittle like the torsionbars in a suspension.
Most of the force you use to turn is being used to twist the extension instead and you only got something like 30-40% of the force down where you need it to be (just made up that number)
Use a shorter extension or put a piece of pipe on the handle to give you more torque
How does the extension look like that you are using?
Does it look like this:
Or this:
Notice how they are different at the end where you use the ratchet and socket.
The first one is useless the more force you use on it the more it will twist like a torsionbar and then finally snap.
I dont know how many of those o have destroyed untill i found the other one.
The second wont twist so easy, i have never destroyed one that looks like that.
Pierre_r is online now
post #7 of 9 Old 09-05-2013, 05:21 PM Thread Starter
JeeperSC
Or this:
It was like the first one. I was using 3 crappy extensions and an elbow. Cheap tools and inexperience.
I ended up getting the spark plug out without removing anything else. By replacing the plugs it fixed an idle issue I was having an it runs smoother.
Thanks for all the help!
Steel Blue Metallic
JeeperSC is offline
post #8 of 9 Old 09-05-2013, 07:40 PM Thread Starter
JeeperSC
Here are 5 of them. One or all was causing a bump while at idle.
Steel Blue Metallic
JeeperSC is offline
post #9 of 9 Old 09-10-2013, 06:01 AM
vadslram
Those plugs look good.
Good and worn but no indication of a problem.
Pierre, If you can torque a steel shaft that has a shear point of 11,000 lbs with your bare hands and a breaker bar, you need to register with Guiness world records.
You figure the tortional strength using:
θ = L T / (Ip G) (5)
where
θ = angular shaft deflection (radians)
L = length of shaft (mm, in)
G = modulus of rigidity (Mpa, psi)
Low carbon junk steel is like 860 inlbs to yield, depending on composition it is 3 times that to deformation. with a 10" breaker bar you would need to put almost 250 lbs to twist it. If the plug still sticks at that much torque the threads are going to be crap when you get it out anyway.
vadslram is offline
