Help with power steering issue? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Help with power steering issue?
HID's from RuffStuff!Ruffstuff Axle Simple Swap Kit!The Original 3/8" Ruffstuff Diff Cover!
Unread 07-21-2012, 10:44 AM   #1
Mercrae
So I recently replaced my bad power steering pump, flushed the lines and everything was working fine afterwards. A few days later I was turning into my driveway and lost all power steering. No noises from the pump so I don't think that is it. When I am accelerating, the wheel turns easier but it is damn near impossible while not in motion. Any advice? Its an 02 grand Cherokee. Limited with 4.7 v8 mfi.
Mercrae is offline   Reply With Quote
Unread 07-23-2012, 10:45 AM   #2
Mishimoto
Well does it turn easier with higher rpm's or with speed? If it's easier with speed, I'd think pump. Easier with rpm either restriction in the lines or pump. Where did you get the new pump from?
Mishimoto is offline   Reply With Quote
Unread 07-23-2012, 03:33 PM   #3
Mercrae
Haven't checked with rpm or speed, just know that it turns easier if moving (obviously). I got the pump from Autozone due to price which I am sure was dumb. What about the steering gear assembly?
Sent from my DROIDX using JeepForum
Unread 07-23-2012, 03:44 PM   #4
Mishimoto
I'd be leaning towards the pump, sometimes the reman units go out randomly like that.
Unread 07-23-2012, 05:49 PM   #5
Mercrae
Even if it doesn't make any noise?
Unread 07-24-2012, 07:08 AM   #6
Mishimoto
There is a seal that likes to go out on gearboxes, but when it does, you lose all your power steering fluid. If you still have fluid in the system, then you'd have a lack of pressure. So either blockage in the line or the pump.
