Originally Posted by stormkaster
thanks for the help guys, went back to napa and just went old school and looked threw the Clevite parts guide and found all the right part numbers... if i change the pistons and rings will i need to change anything else?
Have you miked the cylinders yet? You will need to if you plan on trying to get away with not boring. Be sure to check the top and bottom after honing to insure a proper reading.
Machine shops used to knurl piston skirts to refit pistons into worn bores. With the advent of modern electronics and machining, this practice has fallen by the wayside. You can ask your machinist if he has the equipment to do it, and if so, then I would recommend getting it done. Again, best thing is to simply do the nasty and bore.
all the berrings all still fit well using the STD. size and the crank is still in balance..
Be sure to plastigauge the bearings to insure proper clearance. An extra thousands can mean the difference between good oil pressure and bad.
