help with pistons - JeepForum.com
post #1 of 25 Old 02-11-2010, 01:11 PM Thread Starter
stormkaster
help with pistons
Im doing a rebuild on a 4.2L 258 for my yj and i am going to get it bored out to a .030 over bore, now the problem i hae now is selecting what pistons to use i have the option of the Kohler, Brigg & Stratton and Tecumseh also what HP raiting would i need (8, 10, 12, 14, 16 i think i have the option of an 18 as well) cant find any info on the net and my local Jeep dealership is as dence as the front bumber on my XJ!
and help would be appreiciated
Thanks
stormkaster is offline
post #2 of 25 Old 02-11-2010, 01:49 PM
mdm
Farm Wheeler
Are you rebuilding a Jeep engine or a lawn mower? I've never seen AMC 258 pistons made by any of those companies or a Jeep engine with 8-18 HP.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 25 Old 02-11-2010, 01:53 PM Thread Starter
stormkaster
its just the piston hp rating not the engine hp rating, if it didnt make a diffrence im sure i would be given the option
post #4 of 25 Old 02-11-2010, 01:57 PM
mdm
Farm Wheeler
Do you have a link for any of these pistons?
I just rebuilt my 4.0L and did a bit of research on available parts and didn't see any pistons made by those companies or that were listed by HP rating.
mdm is offline
post #5 of 25 Old 02-11-2010, 02:01 PM Thread Starter
stormkaster
dont have a link, going on what is infront of me on the computer of course NAPA and the dealer could be full of it! Unfortunatly i cant seem to down track anything to say otherwise.
like i said help would be appreciated
post #6 of 25 Old 02-11-2010, 02:06 PM Thread Starter
stormkaster
would the 4.0L pistons work in the 4.2L?
post #7 of 25 Old 02-11-2010, 03:07 PM
CJ258
1974 CJ5
If your pistons are in good shape you could just run over sized rings. That was a common practice at one time and could save you a bit of cash for other upgrades.
CJ258 is offline
post #8 of 25 Old 02-11-2010, 03:33 PM Thread Starter
stormkaster
i spent a lot of time cleaning the crap off the pistons and there all in grat condition, just using over size rings wont cause any knocking in the cylinder? sorry if its a stupid question, first rebuild and learning as i go
post #9 of 25 Old 02-11-2010, 05:50 PM
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
4.0L pistons won't work because they have different pin heights.
lots of choices here's just 1 source. Jeep Parts PISTONS WITH PINS
I'd try Summit also, and if your going to bore it go big! .060 over!
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline
post #10 of 25 Old 02-11-2010, 07:37 PM
ClimbStuff
Thanks
LOL WAT?
ClimbStuff is offline
post #11 of 25 Old 02-11-2010, 08:24 PM
CJ258
1974 CJ5
It was a common practice and I'm sure machine shop still do it. If your bores aren't out of round you may just have them honed. Talk to the shop prepping your block and see if they are within tolerances. Can't hurt to ask.
CJ258 is offline
post #12 of 25 Old 02-11-2010, 10:25 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
You should be saying "if your cylinders are in good shape". Generally speaking this is correct, however, the reality is if your going to be keeping the Jeep for a while, your are money ahead to to go ahead and bore the cylinders. This insures they are true and within specs.
As for your piston choices, I think you clicked on the wrong button. Most pistons are offered by differences in composition, not HP rating. For slow spinning engines such as ours, you don't need high end forged slugs. This goes for a cam as well. I suggest you stay within the stock or RV grinds to see the best drivability. My recommendation is to purchase a master engine kit from a reputable vendor. This will include a ground crank, proper pistons, cam, all bearings and seals, pretty much everything you will need in one package.
jeepdaddy2000 is offline
post #13 of 25 Old 02-12-2010, 12:46 PM Thread Starter
stormkaster
im statrting to think they typed the wrong criteria into the computer at napa, i should check with the shop to see if my engine can be bored out to a .060
post #14 of 25 Old 02-12-2010, 01:18 PM
EJames1226
EJames1226's Avatar
Make sure you stagger your rings when you put em back in.
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline
post #15 of 25 Old 02-12-2010, 02:21 PM Thread Starter
stormkaster
thanks for the help guys, went back to napa and just went old school and looked threw the Clevite parts guide and found all the right part numbers... if i change the pistons and rings will i need to change anything else?
all the berrings all still fit well using the STD. size and the crank is still in balance..
metric pistons? jeep795 Engines & Drivetrain 0 05-09-2009 07:37 AM
using chevy pistons in a 4.0 SuperStreetJeep Engines & Drivetrain 5 04-17-2009 10:16 PM
Pistons for 360 Mackddy6 Engines & Drivetrain 2 12-07-2001 08:28 PM
Oversize Pistons mde Engines & Drivetrain 2 11-28-2001 07:11 PM
Pistons Mackddy6 Engines & Drivetrain 0 10-23-2001 08:52 AM
