Help a noob out please - don't know where to start with Engine - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Help a noob out please - don't know where to start with Engine
New! JK/U skid plate system.We now have Uniballs!The Original 3/8" Ruffstuff Diff Cover!
Unread 01-11-2006, 01:32 AM   #1
Mr. Tobes
I just bought a 1991 Wranger that is in pieces. It has a motor from a 1989 Cherokee (6cyl). I am assuming this is a 4.2 based on the research I have done. However, it looks to be missing pieces. Besides that, the engine compartment is basically empty and I don't even know where to start. I hope I am not in over my head here. I was wondering if anyone knew of a good website with parts diagrams that I could order parts from and maybe get a good idea what goes where.
Thanks,
Al
Mr. Tobes is offline   Reply With Quote Quick reply to this message
Unread 01-12-2006, 10:23 AM   #2
Scrambler82
1982 CJ8
Sorry I can't help you with the Jeep much but when I bought my first Harley it was in a basket, ya a basket case.
All i did was buy a manual from Chilton (may not be the best) and started assembling.
As to being over your head, I know the feeling, keep it up and go for it, your call.
Luck,
Scrambler82
Do it right the first time !
Scrambler82 is offline   Reply With Quote Quick reply to this message
Unread 01-13-2006, 05:18 AM   #3
75SV1
I'd start with a Chiltons or FSM (Factory Service Manual). You might look at the Cherokee America webiste or :
http://www.jeep4.0performance.4mg.com/stroker.html
There are some other that might help. The motor you have is a Renix motor and your Cherokee had the HO version. They can be made to work, but some of the wiring is different. Most adapt the HO motor to a Renix bases Cherokee or Comanche (87-90). Look here for info:
http://www.rockmodified.com/2003/april/TB/tb_perf.htm
I have some pictures of my Comanche with the motor in it and the motor I replaced it with. I am not sure if that would help or not. If you have the wiring and electronics, I'd try and find a 91-95 motor in good shape. There is a temp plug in the 91-95 head that earlier and later motors don't have. ALso, is yours a manul or automatic?
Tom
75SV1 is offline   Reply With Quote Quick reply to this message
Unread 01-23-2006, 01:02 AM   #4
Mr. Tobes
It's a manual, Tom
Unread 01-23-2006, 06:48 AM   #5
75SV1
Here's a link that might help:
http://www.cjoffroad.com/
Its for CJ's, but should be close. I am not sure how the emmission laws are there. Actually, I think its EPA law. You can't put in an earlier year for engine into your vehicle. Might check on it. Either manual or auto, you should get the same wiring harness. I'd probably look at a later Wrangler (TJ) for engine, wiring etc. You might look at wreckers or the rebuildable dealers in auto papers. You will be only intersted in the wiring and running components. You might be able to sell off any other good parts.
Tom
Unread 01-25-2006, 10:32 PM   #6
stonehogg
enjin goez undr de hud... wheelz goes undr fendurs...seatz goes bahind de sterin wheelz.. dorz goes in each sidz .... tht shuld du et...
stonehogg is offline   Reply With Quote Quick reply to this message
Unread 01-25-2006, 11:44 PM   #7
gumcrew2
1991 XJ Cherokee
hooket on fonikz werked fer mi
"Nitrous? So is that like viagra for your Jeep?" -mom
"I flopped it"
gumcrew2 is offline   Reply With Quote Quick reply to this message
