Help! NO Start - JeepForum.com
post #1 of 2 Old 06-24-2013, 05:23 PM Thread Starter
Jeep0321
Help! NO Start
1994 2.5L manual shut off driving after seafoam treatment. It'll crank but not start. Changed the plugs, ignition coil, CPS, distributor, rotor, and ECM. Still will crank but not start. Please help.
Jeep0321 is offline
post #2 of 2 Old 06-25-2013, 09:01 AM
LtCdrLange
1997 XJ Cherokee
Crank position sensor is usually the leading cause of all no start problems with jeeps regardless of motor. Not a bad direction to research into... but after a seafoam treatment you may have hydro locked it.. pull the plugs out and crank it to see if any of that crap shoots out. should be a little bit of gas. but let it sit first... make sure plugs arent attached to wires.. otherwise fire ensues.. FYI
LtCdrLange is offline
