So here it goes. '91 wrangler 4.0. I swaped out my injectors for ford 19# injectors. It started fine, but ran a bit rough. Took it out for a drive and it still ran a little rough, but I figured it was the the computer getting used to the new injectors, no leaks. Soon after, I dropped my gas tank because my skid was rotten and needed replacing. I replaced all of the soft fuel lines, vent hose and fuel filter at the same time. Now when I try to start the engine, it just cranks and won't turn over. There is plenty of fuel in the rail and hear the pump running. I've tried to let it sit, then turn the key to on multiple times to let pump fill the system. I am also getting fuel in the return line. During one of my attempts to start, I notice a small puff of smoke on the rear passenger side of the engine, but can't tell where it came from. I have tried to start it several times since, but it still just cranks. No further smoke. Battery is fully charged. Any help would be greatly appreciated.
Thanks my skid was rotten and needed replacing. I replaced all of the soft fuel lines, vent hose and fuel filter at the same time. Now when I try to start the engine, it just cranks and won't turn over. There is plenty of fuel in the rail and hear the pump running. I've tried to let it sit, then turn the key to on multiple times to let pump fill the system. I am also getting fuel in the return line. During one of my attempts to start, I notice a small puff of smoke on the rear passenger side of the engine, but can't tell where it came from. I have tried to start it several times since, but it still just cranks. No further smoke. Battery is fully charged. Any help would be greatly appreciated.
Thanks
Thanks
