Help! New head on '98 XJ - JeepForum.com
post #1 of 6 Old 08-28-2012, 11:50 AM Thread Starter
JonDietz
I am installing a new head on my 1998 Jeep XJ, I have looked around several forums and cannot find what I am looking for. I have the head bolt torque pattern and so on but is there any adjusting that needs to be done to the push rods and rocker arms when installing a new head? I have done work on a Harley and I had to turn the motor over to top dead center on each cylinder... not entirely sure and DO NOT wanna blow up my new head.
JonDietz is offline
post #2 of 6 Old 08-30-2012, 08:59 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
When you remove the valve cover to start the head removal you will see the tops of the push rods with the rockers on top then pivot assemblies and last but not least the bridge that holds them in place using to bolts.
KEEP THEM IN THE EXACT ORDER YOU REMOVE THEM.
Installation is the reverse procedure. Tighten them down ONE TURN AT A TIME until you hit the torque value of 21 ft lbs. No engine rotation is needed.
I would use engine assembly lube of some sort and coat all the friction points during assembly.
I'll post a picture in a minute.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 6 Old 10-01-2012, 01:07 PM
Matt The Hammer
Are the pivot assemblies directional? There is a groove for oil on them. They aren't parallel. One side is wider between the grooves than the other.
The FSM didn't specify which way to orient them. I didn't realize they were directional until I removed the last one.
Thanks.
2013 JKU
1995 YJ
Matt The Hammer is offline
post #4 of 6 Old 10-01-2012, 03:55 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Thanks.
Why do I think the grooves furthest apart faces the pushrod IF the FSM picture is what I think it is showing?
I replaced my head because it cracked. During the teardown I pulled each set of rocker bridges/pivot assemblies off, cleaned them and put them back together again without changing the orientation.
I would check out the rocker assemblies. There must be a section that has no wear marks from friction. That is where the 'dent' in the pivot assemblies would ride I would think.
post #5 of 6 Old 10-01-2012, 04:00 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Check out figure #1
http://www.autozone.com/autozone/rep...00c1528008a96c
post #6 of 6 Old 10-03-2012, 02:31 PM
Matt The Hammer
Thanks. I didn't try to re-assemble it yet. Maybe, like you said in your first reply, there is a non wear spot. When I disassembled it, I put each rocker assembly in it's own bag, so I lost the exact orientation of the assembly because the FSM didn't mention saving it - only the other items. Obviously the push rods, rockers and even each bolt (head, cover, assembly) were saved in order.
Used that classic trick I learned of 'Wheeler Dealers' where you push each removed bolt through a piece of cardboard with a drawing of the engine on it. Funny to have a few pieces of cardboard with bolts going through them laying around.
2013 JKU
1995 YJ
4.2 40 head and fuel inj Adamjohnson Advanced Jeep Tech 1 07-17-2012 02:05 PM
4.0 Head and MPI Swap to CJ - What is this thing? dirtyb Advanced Jeep Tech 3 04-16-2012 08:09 AM
