Help identifying a small block chevy engine that my YJ wants. - JeepForum.com
post #1 of 3 Old 12-27-2009, 06:46 AM Thread Starter
schwebel
For some reason I seem to aquire stuff that lays around in other peoples garages for free. A couple weeks ago I got a free AMC 360, then a 71 CB500f Honda, and now a SBC. I would love to put this in my YJ, but am trying to find out factory specs on this engine. The casting number is 3970010, I cannot find the head number? There is no little plate on the head like I've seen in most of these motors. The by the water pump housing is V0429TBC. Dunno what that means? Anyone have expierence identifying these engines?
schwebel is offline
post #2 of 3 Old 12-27-2009, 07:16 AM
BigDumbBear
1978 CJ7
3970010....350...69-80...2 or 4 Found on this site. MorTec, Inc. Chevy Smallblock V-8 Casting Numbers List
350ci, year range 69-80 with 2 or 4 bolt mains. That's a pretty common block. I seem to recall the head casting numbers being found under the valve cover.
If you keep getting that much free crap, we need to hang out. lol
Oh, I'm in no shape to be reading, but here is the casting number locations. Chevy V-8 Engine Block and Head Casting Number Locations
If it ain't broke, fix it till it is!
Efficiency is the lazy man's way of getting something done.
I have not failed, just succeded in finding many ways that did not work.
Originally Posted by stpeteTJ View Post
Haha, that's not a safety. That's a danger-y.
BigDumbBear is offline
post #3 of 3 Old 01-08-2010, 10:18 PM
TdiJetta99
Well, depending on the casting date, it's either from a 1970 pickup with 255hp, or a 1979 pickup with 165hp.. The TBC suffix denotes a 4-bolt main block, and the part number (3970010) is a very common block used in the 70's of which there were a few variations.. sounds like a keeper.. a set of vortec heads and a roller cam and she'll be a screamer..
95 Wrangler 2.5 Auto (stock for now)
81 Camaro 454/700R4 (high 11's, 3900lbs, 19mpg)
94 FS Blazer 6.5TurboDiesel (almost stock)
99 VW Jetta TDI 5-speed. 50+mpg, will go 145mph.. Not stock...
TdiJetta99 is offline
Is there a small cap HEI,chevy CajunCountry Engines & Drivetrain 6 08-18-2009 11:39 PM
350 small block case'sjeep Engines & Drivetrain 1 06-13-2007 06:54 PM
small block and big block difference tjboy Engines & Drivetrain 3 03-03-2005 08:35 PM
Small block ?'s.. lavoo Engines & Drivetrain 3 04-09-2004 08:07 PM
Identifying the original source of a 350 ci Chevy JunkJeep? Engines & Drivetrain 2 07-23-2002 10:18 PM
