help, having trouble w/ my 8.8 - JeepForum.com
post #1 of 9 Old 01-23-2007, 08:43 PM Thread Starter
jipjip
jipjip's Avatar
i installed the 8.8 in my rig about 5 months ago. it has served me well, but from day one, it has had play in the gears (not sure where from). it does not seem to be getting any worse, but i can move the rear driveshaft almost 1/8 of a turn before any gear engagement is felt. i know it's the rear, but not sure where it's coming from. i havn't opened it up yet, but i was wondering if there are some common problems w/ these rears to cause excessive amounts of play.
it is out of a 97 exlorer, has 4.10 gears, and a lsd carrier. no noise or vibrations are coming from it. just this excessive play, which honestly makes me nervous to wheel.
is there common issues w/ the lsd clutch plates wearing down and causing play, or maybe spider gear thrust washers causing play? i can't see a ring and pinion causing this much play, and there's not slop in the bearings.
HELP!!!
thanx in advance.
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,tnt customs front tube fenders w/ 6" flare,warn gas tank skid, skidrow oil pan skid,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,35" toyo open country m/t's, 1" daystar body lift, warn 9.5ti
jipjip is offline
post #2 of 9 Old 01-29-2007, 06:16 PM
notmyj
The drive shaft freeplay is directly related to the ring and pinion back lash. if its not getting any worse, and not making any noise you should be fine. Especially if it is a factory gear set from ford. If the gears have been changed then I would have it checked by a good drive line shop. IF you need them I can get you the factory specs on the backlash for the 8.8. Let me know I can help at all.
notmyj is offline
post #3 of 9 Old 02-06-2007, 02:20 PM
blacktjsport
I do know that the LSD carriers seem to wear out faster than the open carriers. I dont know if this is the cause of the excessive play or not, but I would have it opened up and checked out before I got stranded in the woods with a busted rear end!! Something seems to tell me that it's the clutch packs in the LSD wearing out but I could be wrong. HTH and the only really way to tell is to open it up and spin the gears and see where the play is coming from.
-Matt
~~2000 Black TJ Sport~~
-Parts list keeps growing...
blacktjsport is offline
post #4 of 9 Old 02-06-2007, 04:52 PM Thread Starter
jipjip
jipjip's Avatar
yeah, now i have this wierd tinny clicking noise when i take off from a dead stop. it's just getting noisier as i go.
jipjip is offline
post #5 of 9 Old 02-11-2007, 08:58 PM
ORmudslinger
ORmudslinger's Avatar
Had an 8.8 in a Ford Ranger. Seemed like it had excessive gear play. Mechanic says it was normal for that axle. Far as the clicking that is another story. I did not have a LSD.
Sell crazy somewhere else...we're all stocked up here.
ORmudslinger is offline
post #6 of 9 Old 02-12-2007, 12:48 AM
jawsgear
jawsgear's Avatar
Tinging noise could be a bad ujoint. As far as the play, typically Ford OEM gears run at about .012 to .015 in backlash. If you have a stock posi they are known to wear the clutches and cause extra slop as well. I would definatley check it out. Being proactive usually costs you less money in the long run.
Jeff
We stock a complete line of differential parts for all your offroading needs. Gears, Positractions, Lockers, Axles and more Give us a call and save money on top quality parts.
jawsgear is offline
post #7 of 9 Old 02-21-2007, 12:52 AM
TXjeepTJ
TXjeepTJ's Avatar
if you have a manual, a little bit of driveshaft play is normal
now if your driving and let off the gas at a low rpm in a low gear and you hear a "clunk clunk clunk"- the sound of the pinion gear using its remaining teeth to grab the ring gear
congrats, you rear end is blown!
shouldnt be the case if you got an 8.8 tho
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #8 of 9 Old 02-21-2007, 09:17 AM
jason m
Nothing but the facts
jason m's Avatar
hurry up and get that 14 bolt, LOL jason.
jason m is online now
post #9 of 9 Old 02-21-2007, 10:55 AM Thread Starter
jipjip
jipjip's Avatar
none of the above sounds like it's the problem.
i know the clutch plates have a little slop in them, but i've never heard of a tinny noise being made by gears. it could be a broken lsd spring, but that would probably cause noise all the time, and not just when taking off.
i'm going to rip into it tonight, and i'll let you guys know what i find.
thanx for all the help though.
jipjip is offline
More SWR trouble Troy591 Audio, CB & Ham Radios, GPS, & Electrical 37 01-28-2008 06:37 PM
cb trouble alex71 Audio, CB & Ham Radios, GPS, & Electrical 9 04-18-2006 10:28 PM
cb trouble magoo_16_99 Audio, CB & Ham Radios, GPS, & Electrical 7 06-13-2005 03:56 PM
sub trouble VTJeep11 Audio, CB & Ham Radios, GPS, & Electrical 7 04-18-2005 09:48 AM
still having trouble twotone Tires & Wheels 2 09-12-2004 11:04 AM
