help with gas mileage - JeepForum.com
post #1 of 7 Old 07-19-2002, 02:32 PM Thread Starter
badl
does anyone have advice for improving gas mileage on a 98 sahara? Wondering if all the parts that claim to improve fuel economy actually do (air filters, exhaust, TORNADO, ect)
badl is offline
post #2 of 7 Old 07-20-2002, 12:25 AM
91XJLimited
91XJLimited's Avatar
Intake and exhaust gave me noticable power increases, and about 2-3 more mpg in city. I dont personally have the Tornado, but many people, and even our local news station (news doesnt happen a lot in OK) say that the Tornado makes no difference whatsoever. Get the intake, exhaust, and headers if you like. I'm sure they will more than do what your looking for.
91 XJ Limited - RE 5.5" XD, 32x9.50 TSL's, 4.0 HO, disconnects, other good stuff
94 ZJ 5.2 Limited - 6.5" Teraflex lift, Clayton Long Arms, disconnects, 37x12.50 SSR's, Hummer Beadlocks, and more good stuff
91XJLimited is offline
post #3 of 7 Old 07-23-2002, 03:23 PM
Steve28
Steve28's Avatar
A Jacobs ignition would help IV been looking into getting one for my 89 and I have only herd good things about them
89 YJ with: 2.5 OME, SOA, MX-6 shocks, 33" ProComp MTs, AE. 589 rims, SYE + CV driveshaft, Homemade Bumper and nutter bypass. Also looking for some 44s to put under it.
Steve28 is offline
post #4 of 7 Old 07-30-2002, 11:31 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Not trying to be cocky, really, but good luck trying to improve mileage on any Jeep, LOL.
Honda Civic will help, as a starting point, LOL
4wheeler4CJ is offline
post #5 of 7 Old 07-30-2002, 07:21 PM
evilpsych
evilpsych's Avatar
ok here's the list on mine (so far)
hi-flow filter
MSD ignition w/ blaster 2 coil and magnecor spark plug wires.
spark plugs regapped to .050
borla header
carsound high-flow catalytic converter
borla cat back exhaust
havent installed the exhaust components yet, but i've noticed a huge difference with just the MSD ignition and regapped plugs. havent gone through enough gas to know of mileage improvements yet however.
you might also want to try replacing your fuel injectors as they may be clogged and worn out. Check your fuel lines also, there could be leaks. if you havent, it might be time to replace your O2 sensor. clean your throttle body. If you have oil in your air filter, spray carb cleaner into the tube going from the valve at the BACK of the valve cover into the intake manifold. Check your EGR canister. If it's full of liquid gas, you might wanna replace the charcoal and check the lines there.. check for vaccuum leaksas well.
Just basic maintenance will keep your rig working at full performance. If you've increased the size of your tires, replace the speedo gear so you get proper odometer and speedometer readings.
If you have a hard top, leave it on, the aerodynamics are better, you get better mileage than a soft top, and a soft top gets better mileage than no top at all. Expect mileage decreases of 5-10% with larger tires depending on your diff gearing. The added rotational weight decreases performance also. Lifts and high angles in your driveshafts also decrease performance
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #6 of 7 Old 07-30-2002, 07:22 PM
evilpsych
evilpsych's Avatar
of course, a jeep is as aerodynamic as a sheet of plywood..
oh.. the exhaust manifold is prone to cracking.. check that as well and repair or replace it to gain back power and mileage
A
post #7 of 7 Old 07-30-2002, 07:23 PM
evilpsych
evilpsych's Avatar
and avoid the throttle body spacer.. everyone i've talked to has said that it sucks the most.
A
bfg mt km mileage and tsl radial mileage epeck87 Tires & Wheels 1 03-29-2009 09:53 AM
LTB Mileage SkyChi Tires & Wheels 7 10-27-2008 08:10 PM
4.10/4.56 gas mileage? morningwood1429 Engines & Drivetrain 18 02-08-2008 11:17 PM
AT vs/MT mileage? terrible Tires & Wheels 3 04-02-2006 02:00 PM
Gas mileage JeepnTX Engines & Drivetrain 3 03-07-2003 04:45 PM
