Help with a ford solid axle swap - JeepForum.com
post #1 of 4 Old 07-17-2007, 10:02 PM Thread Starter
bgstjrkinthwrld
Hey jeep gurus, I realize that I am asking an odd question, but I need help.
I have a 96 f-150 4x4 6in lift for my trail beater and the ifs front end is falling apart! I think I may want to replace the whole mess with a solid axle setup rather than replacing all the bad parts on the independent front end. Where do I look for info about this? Has anyone done it?
Thanks
bigjerk
bgstjrkinthwrld is offline
post #2 of 4 Old 07-17-2007, 10:45 PM
Trouble Maker
reckless endangerer
Trouble Maker's Avatar
Thanks
bigjerk
On a Ford site would be a good choice.
Russ
02 Dakota Quad Cab 4.7 5 spd
93 ZJ Stolen and wrecked Mar29/08
Trouble Maker is offline
post #3 of 4 Old 07-18-2007, 12:33 AM
JeepMKcomin
ford-trucks.com has a nice forum with good information.
What you will need to do when you choose an appropriate front axle is get rid of all the ifs mounts and weld on brackets to accept control arms, coil buckets, and shock mounts for the solid axle. I imagine there would be quite a bit of custom work.
Go to those forums and ask around. Good luck!
06TJ Silver Ruby - REBB w/DT3000s, Quick Discos, Superwinch EPi9.0, Warn engine skid, PS Box Skid, Diff Guards, IPF Lenses, x51s soon
92YJ White - Slight Shackle Lift w/30x9.5 BFG ATs, Custom Beefy Bumpers
06TJ Khaki Sport - Traded in
JeepMKcomin is offline
post #4 of 4 Old 07-22-2007, 03:12 PM Thread Starter
bgstjrkinthwrld
thanks for the tip on ford-trucks.com Ill check it out. There are so many dang sites when you put in a few word in a search engine. Hard to know whats good out there. later
Solid axle swap information?? dimreality22 Engines & Drivetrain 5 01-10-2009 05:59 PM
Chrysler to Ford 8.8 axle swap? Shadow83 Street Jeep Forum 4 05-29-2008 10:00 PM
IFS to Solid Axle Swap StokedXJ11 Engines & Drivetrain 4 09-17-2006 01:11 AM
Ford Explorer Axle Swap 00Vert Engines & Drivetrain 65 07-02-2006 11:21 PM
Ford 8.8 Axle Swap Stormtrooper Fabrication Shop 12 01-02-2006 08:16 PM
