Help with engine code I.D. - JeepForum.com
post #1 of 3 Old 04-08-2013, 10:33 PM Thread Starter
89YJBuilder
I just bought an 85 Ford bronco. Just a parts donor. I know it has a 5.8 but not sure if it is a Windsor or Cleavland? The engine code in the vin is an H. Can someone help with that? Also I believe it has a 9" rear because it has a third member but I don't know anything about the 10.25". Well if thees are what I think they are they are worth the $200 I paid.
If this is correct I only need a front axle at this point. Well I would have to rebuild all of it but I'm closer.
Keep your boogger hook off the bang button!
When all else fails... ham radio is there!
KG6YSF
89YJBuilder is offline
post #2 of 3 Old 04-09-2013, 07:47 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Unless it has been swapped, it should be a Windsor
google an image, the engines are very different.
jeepdaddy2000 is offline
post #3 of 3 Old 04-09-2013, 11:19 PM Thread Starter
89YJBuilder
Ford 9" and a 351W for $200 not too bad I think. I am also not going to need to smog because I live in an "Unimproved Area." Only smog when buying or selling and I ain't selling. So I get a front axle and a bell housing and start rebuilding all the collected parts. So far I have a '85 351W, '78 NP435 (way low first gear), '78 NP 205, and a '85 9" rear axle. My little red '89 YJ will be pretty well set. I'm thinking 35s, 4.88s, Detroit Locker rear and a ? selectable in the front axle what ever it happens to be. I would also like to find an NP203 to do a doubler eventually.
KG6YSF
