Help!!! Dead Jeep after washing engine!! - JeepForum.com
post #1 of 3 Old 07-27-2002, 01:07 PM Thread Starter
crownlvr
I needed to wash my engine after getting stuck in the mud...searched the forum for advice and decided to go the Simple Green route...got my engine VERY clean...gently rinsed off the Simple Green and started the Jeep...
It started right up, ran for about 3 seconds and stalled. Went to start it and all I get now is a rapid, fairly loud clicking noise when I try and crank the engine. I'm assuming this is a starter issue, but I'm new at this so I'd appreciate any help or ideas!
If I do need a new starter, is that a job that I can do myself? I'm fairly mechanically inclined (put in a few lifts, changed carburetors, etc...) but don't want to break anything else!
Thanks!
1989 258ci--100K miles on original Peugeot (maintained by daily prayers)--33" all-terrains w/ 3" body lift (hey...that's how I bought it)--next upgrade...suspension lift...NO CHROME ON THIS JEEP (that's for you Lance!)
crownlvr is offline
post #2 of 3 Old 07-27-2002, 01:41 PM Thread Starter
crownlvr
More info on my problem
Just checked my voltage...battery is running 13V and the connections on the starter are the same, so it looks like my starter is getting enough juice???
crownlvr is offline
post #3 of 3 Old 07-28-2002, 01:41 PM
drtjmpr17
drtjmpr17's Avatar
sounds like your starting silenoid. give her a couple a whacks with a hammer... and if that doesn't work... disconnect the power and give her a couple of whacks.... sounds like its just stuck....
this should free her up
also check the positive and ground........ battery
or turn it over while someone checks the voltage at the starter
now if it was just the starter why would it stall?????????????
cause the starter is only engaged in the start position.........
check fuses,, inside the jeep and in the power box under the hood....
97 TJ : 5.0 HO with skyjacker 6" RR 2.5 body lift ,38x12.5x15 superswamper TSL's. 8.8 rear end
proud supporter of jeep forums
Green Jeep Club Member #4
drtjmpr17 is offline
Washing the Engine lostsock Engines & Drivetrain 9 03-20-2009 07:45 PM
Dead Jeep lightwalk333 Audio, CB & Ham Radios, GPS, & Electrical 3 03-04-2009 11:56 AM
Radio Dead and Dome Lights Dead bigjeep310 Audio, CB & Ham Radios, GPS, & Electrical 11 03-15-2004 01:04 PM
Emergency - Dead Jeep Spalding Engines & Drivetrain 2 02-01-2002 02:07 AM
washing the engine EricsXJ Engines & Drivetrain 10 10-26-2001 01:26 PM
