HELP! Cant get rear main bearing cap out... - JeepForum.com
post #1 of 3 Old 04-14-2012, 10:19 AM Thread Starter
JeepinJordan
doing a rms replacement, pulled the bearing cap girdle, and the rear main bearing cap wont budge or come out, trying not to use anything to nick the metal, but how to i get it out. It wont budge at all and i have to get it out to replace the bottom part of the seal. thanks
-Bone stock 1996 Jeep Grand Cherokee Laredo 4.0L
JeepinJordan is offline
post #2 of 3 Old 04-14-2012, 11:18 AM Thread Starter
JeepinJordan
Ok never mind.. got it out, hit my head on its way down. Lol. The seals are impossible to get out... any pointers...
post #3 of 3 Old 04-14-2012, 12:36 PM
jnicewan
I usually use a small punch to try to push the seal up and around to the other side, sometimes you might have to tap on the punch a few times to get it to move, they are kind of tight. Be sure to pay attention to how the seal looks and put the new one in the right way.
I have known people to loosen the other main caps a little to get the crank to loosen slightly for help too, but I have never had to that. Make sure to put a small amount of sealant on the corners of where the rear cap goes to the block (behind the alignment dowels to rear face). And also be sure to put a small amount of sealant on all four corners of the pan gasket ( front cover and rear main cap corners )
jnicewan is offline
Rear main bearing too wide? cyoos Engines & Drivetrain 0 05-22-2009 04:29 PM
Main Bearing condition? 258 whittlecj Engines & Drivetrain 0 09-30-2008 10:07 PM
oil leak & rear main bearing elfman69 Engines & Drivetrain 3 06-06-2007 07:24 AM
worn out main thrust bearing amcpapa Engines & Drivetrain 3 05-07-2002 06:28 PM
