Help! Can't disconnect engine...... - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Help! Can't disconnect engine......
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 07-24-2005, 11:07 PM   #1
jagriffinsf
I finally got those torx bolts off of the transmission bellhousing. Now I'm trying to lift the engine out but no matter what elevation I try, I can't get the damn thing to separate from the tranny. PLEASE HELP!
I have already double checked to make sure nothing is in the way. The engine is currently separated by about 2 inches. It just won't go anymore....
jagriffinsf is offline   Reply With Quote Quick reply to this message
Unread 07-25-2005, 01:08 AM   #2
Traveller
Did you unbolt the torque converter from the flex plate? (if you have an auto), if you have a stick it also helps to ubolt the clutch pressure plate from the flywheel. If you don't, even being only a couple degrees off axis to the tranny input shaft can make it a pain to remove the engine (or trans).
Traveller is offline   Reply With Quote Quick reply to this message
