Help! Can't disconnect engine...... - JeepForum.com
post #1 of 2 Old 07-24-2005, 10:07 PM Thread Starter
jagriffinsf
I finally got those torx bolts off of the transmission bellhousing. Now I'm trying to lift the engine out but no matter what elevation I try, I can't get the damn thing to separate from the tranny. PLEASE HELP!
I have already double checked to make sure nothing is in the way. The engine is currently separated by about 2 inches. It just won't go anymore....
jagriffinsf is offline
post #2 of 2 Old 07-25-2005, 12:08 AM
Traveller
Did you unbolt the torque converter from the flex plate? (if you have an auto), if you have a stick it also helps to ubolt the clutch pressure plate from the flywheel. If you don't, even being only a couple degrees off axis to the tranny input shaft can make it a pain to remove the engine (or trans).
Traveller is offline
Disconnect Pin gabriel05 Fabrication Shop 9 03-03-2009 09:13 AM
CB Disconnect shunt Audio, CB & Ham Radios, GPS, & Electrical 5 06-23-2007 07:40 PM
To disconnect or not to disconnect... Jeeper Jeff Audio, CB & Ham Radios, GPS, & Electrical 3 12-15-2006 10:07 AM
how to disconnect the sub... Dylans01jeep Audio, CB & Ham Radios, GPS, & Electrical 4 06-10-2006 01:00 PM
if i disconnect can i... paroxysym General Jeep & Off-Road Equipment 11 09-28-2005 02:06 PM
