Help! 4.0L Fuel? Problems - JeepForum.com
post #1 of 1 Old 05-30-2012, 09:59 AM Thread Starter
Braz
Alright, so I'm nearly at my wits end trying to figure out my fuel problems.
Vehicle - 91 Comanche. 4.0L. 170k mi.
Problem - Jeep starts and idles fine. Drive OK while cold, warms up pretty quick. After warm, when starting from a dead stop, the Jeep stumbles heavily under throttle. (Very delicate throttle application does not cause a problem). If i stay on the gas, she'll die. If i let off it'll stumble for 15 seconds before coming back around (at which point i'll be at a dead stop).
I've replaced -
Fuel Pump (Bosch)
Plugs
Fuel Filter
Threw in newer (cleaner) injectors from my old 97 XJ (I assumed their compatible).
Before I went to the Bosch Pump, I had some buzzing coming from a cheap-o pump. I checked the pressures at that time and it was 29 and 37 with the vacuum plugged and unplugged, but I haven't checked it since I replaced the pump.
The Jeep had been cutting out under throttle but not nearly as bad, and died on a hot day (only had problems at temp again). So I had gone ahead and replaced the pump. Figured the cheap pump was still causing problems since it was buzzing, so I replaced it with a Bosch.
Could it be the FPR, even though previously my pressures were in range? I can't think of anything else that I could be.
From what I can tell, everything else on the Jeep is stock, most of it may be original. I had driven it for maybe 10k miles before it ever gave me any problems (aside from leaky injector delayed starting).
Thanks for any help,
Braz
Braz is offline
fuel problems slickonetwo Engines & Drivetrain 1 04-16-2012 10:48 PM
fuel problems MoparXJ Engines & Drivetrain 0 04-03-2012 09:51 AM
fuel problems Aaronhouck Engines & Drivetrain 2 12-24-2011 12:29 AM
Fuel Pressure Problems JFuqua Engines & Drivetrain 2 06-02-2010 09:43 PM
Fuel Problems MidnightRacer Street Jeep Forum 7 06-11-2006 04:44 PM
