Help, 258 backfiring out of exhaust ?! - JeepForum.com
post #1 of 8 Old 04-19-2004, 06:03 PM Thread Starter
Baloo
Go Tigers!
Baloo's Avatar
1982 CJ7
Hello. My 258 just started backfiring out of the exhaust a couple days ago. I havent driven it since then. When I crank it, it even backfires when idleing. I've tried adjusting the idle and mixture screws on the carb, but that doesn't work. I just don't have a clue. I'm learning as I go here and I haven't come across this yet.
Thanks,
Elliott
1982 CJ-7
AMC360
4.5" RE 35" X's
Blue Jeep Club Member #1
Baloo is offline
post #2 of 8 Old 04-19-2004, 11:06 PM
Orange Juice
Thanks,
Elliott
Possibly a piece of carbon between exhaust valve seat and face. This would keep valve from being able to shut completely. You can get a fuel additive that will clean fuel system and valves. Don't know if it will work but it won't hurt anything.
To eliminate the carb as the problem, slowly close choke (by hand)while idleing and see if it stops or gets worse. If you are getting a backfire due to a lean condition of the carb, this should temporarily richen it up and cause it to stop.
Orange Juice is offline
post #3 of 8 Old 04-20-2004, 12:40 PM
Columbia04
Columbia04's Avatar
Have you tried messing with the distributer yet? The timing is pretty easy to check.
'04 Liberty Columbia
'84 Porsche 944
Columbia04 is offline
post #4 of 8 Old 04-20-2004, 01:04 PM Thread Starter
Baloo
Go Tigers!
Baloo's Avatar
1982 CJ7
I got some of that valvoline fuel system cleaner stuff today. I plan on dumping that into the tank tonight. Then check the spark plugs. I will probably have to check the timing too. Just keep em coming guys...You list it, I'll check it until the problem is solved. I just hope it's something external and simple.
Thanks
E
1982 CJ-7
AMC360
4.5" RE 35" X's
Baloo is offline
post #5 of 8 Old 04-21-2004, 02:53 PM Thread Starter
Baloo
Go Tigers!
Baloo's Avatar
1982 CJ7
An observation that may help someone diagnose this is that it only starts the farting, burping and backfiring when it is warmed up.
E
1982 CJ-7
AMC360
4.5" RE 35" X's
Baloo is offline
post #6 of 8 Old 04-21-2004, 06:34 PM Thread Starter
Baloo
Go Tigers!
Baloo's Avatar
1982 CJ7
I checked the timing today and it was below zero!!! I bumped it up to 5 and I am going to bump it up a little more tomorrow.
Also, when I put my hand over the carb the idle speeds way up and it runs really smoothe. When I remove my hand it slows way down and idles roughly. What are your thoughts on this???
Thanks
E
1982 CJ-7
AMC360
4.5" RE 35" X's
Baloo is offline
post #7 of 8 Old 04-22-2004, 07:06 PM Thread Starter
Baloo
Go Tigers!
Baloo's Avatar
1982 CJ7
Good News!
Good news! I finally got it fixed. I advanced the timing to 7 and reset the carb by reducing the idle (to tractor speed) and adjusting the mixture screws to sound, then readjusted the idle. Runs SMOOOOOTHE. I can actually idle at 600 now without it studdering when I hit the gas. I noticed that the distributor cap and rotor have some wear, so I will get new ones tomorrow. Ah, I also ran some valvoline fuel treatment and a full tank of 93 octane. Don't know whether it was one of the things or a combination of all of them that fixed it. It's time for a washy washy now. Its been sitting so long its got about 3 inches of pollen on it.
E
1982 CJ-7
AMC360
4.5" RE 35" X's
Baloo is offline
post #8 of 8 Old 04-23-2004, 07:04 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
E
Good show! You were trying to fix a timing problem by adjusting the carb. The best part is that you discovered it yourself. You won't forget that one!
laybackman is offline
71 Dauntless 225 v6 backfiring cj71225 Engines & Drivetrain 1 01-05-2010 06:05 PM
304 Backfiring out exhaust. rughead Engines & Drivetrain 0 11-21-2008 02:19 PM
Backfiring out the exhaust??? wolf3902 Engines & Drivetrain 3 07-02-2005 08:25 AM
Engine backfiring superjeep Engines & Drivetrain 5 07-21-2004 02:18 PM
Backfiring on deceleration heytat Engines & Drivetrain 7 01-22-2003 11:08 AM
