HELP! 1989 Jeep wrangler bellhousing - JeepForum.com
post #1 of 13 Old 07-26-2013, 01:52 PM Thread Starter
1989wranglerYJ
I have a 1989 Jeep wrangler YJ with a Peugeot transmission. The bell housing has a hole in it about the size of a childs head and I need to find a new one ASAP. Anyone know where I could find one? According to a friend it has a 231 amc peugeot transmission.
1989wranglerYJ is offline
post #2 of 13 Old 07-28-2013, 09:36 AM
jokerchief462
I got 2 bell housings 89 2.5L Ax-5 setup. PM if you need it.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 13 Old 07-28-2013, 04:27 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Wrangler with a Peugeot trans? You sure? AMC 231 is the transfer case number, not the trans.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #4 of 13 Old 07-29-2013, 09:31 AM Thread Starter
1989wranglerYJ
It's a 4.2L inline 6. My mechanic said it was a Peugeot. I've been reading around and for the year it was built a peugeot was not uncommon.
post #5 of 13 Old 07-29-2013, 04:36 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
If you say so.
post #6 of 13 Old 07-29-2013, 04:40 PM
Nafpu
2012 KK Liberty
You have a BA 10/5. You might just be better off locating an AX-15 with bell housing. Much better tranny for the purpose!
95 YJ, gone...
80 CJ7, gone...
12 KK, still here...
Nafpu is offline
post #7 of 13 Old 07-30-2013, 02:15 AM
mmerlinn
Peugeot transmissions in Jeeps are junk. As noted above, you will probably be much happier in the long run with an AX (Toyota) transmission.
mmerlinn is offline
post #8 of 13 Old 07-30-2013, 03:27 PM Thread Starter
1989wranglerYJ
Thank you all! Ill look for an AX-15.
post #9 of 13 Old 07-30-2013, 04:28 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
FWIW, yo can use an AX15 out of a Yota with a clock ring, then you get a better syncros and one for reverse IIRC.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #10 of 13 Old 07-30-2013, 05:41 PM
Nafpu
2012 KK Liberty
The Toyota one is a little different, and all gears on the Jeep AX-15 are synchronized, reverse included...
95 YJ, gone...
80 CJ7, gone...
Nafpu is offline
post #11 of 13 Old 08-01-2013, 02:06 AM
schitzangiggles
King of Macastan
Nope.
"AX-15-66: Remove this snap ring at the synchro hub for 1st/2nd gear. The hub is important, as the outer sleeve doubles as the reverse gear. Hub and sleeve wear could cause gear whine in reverse or cause erratic 1st/2nd shifting. Check hub and sleeve closely. Note the condition of the reverse teeth. Chips and damage are generally the result of grinding the transmission into reverse gear without the vehicle stopped. Reverse is non-synchromesh. Drive in a manner that protects this gear. Even a reusable gear will have some wear at the engagement end of the teeth."
http://www.4wdmechanix.com/Moses-Lud...nspection.html
I have actually had mine out and rebuilt it. No synchro in reverse unlike the Toyota that has one for reverse.
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #12 of 13 Old 08-01-2013, 05:59 AM
Nafpu
2012 KK Liberty
Nope.
Ah well, I stand corrected!
95 YJ, gone...
80 CJ7, gone...
Nafpu is offline
post #13 of 13 Old 08-01-2013, 12:49 PM
schitzangiggles
King of Macastan
Pretty nice article and if only I had it before I did mine it might not have taken 2 days.
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
