Help 1988 jeep wrlanger ingnition switch - JeepForum.com
post #1 of 4 Old 04-11-2013, 05:42 PM Thread Starter
oriti352
I put my key in to turn the jeep on but it just freely turns now I was told its the tumbler but I'm unsure how to even get into the drive column
oriti352 is offline
post #2 of 4 Old 04-11-2013, 05:58 PM Thread Starter
oriti352
oriti352 is offline
post #3 of 4 Old 04-11-2013, 08:32 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Originally Posted by oriti352 View Post
Insert the key into the cylinder and turn it to the ON position.
That 'plate' you see for the horn is held in place with a split ring. Press down on it and remove the split ring. Now pull the plug you see down by the lock cylinder with needle nose pliers. Next remove the screw holding the lock cylinder in place.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 4 Old 04-11-2013, 08:44 PM Thread Starter
oriti352
I was not able to remove anything else I was stuck at this point
oriti352 is offline
