Help - JeepForum.com
post #1 of 2 Old 10-25-2013, 05:06 PM Thread Starter
CHASE3047
Help
I have a 79 cj5 with a three speed transmission. While driving in third gear at around 45 mph a loud whining noise started and the wheels then locked up and i skidded to a stop. The jeep then wouldnt move in reverse or forward. Finally after a few attempts i was able to get it to move in first gear with some shuddering to get it out the road. It now wont shift into second or third but will drive in first gear fine. Also when put in reverse it wont move at all but when clutch is released it will stall out. Any ideas of what i have wrong with it?
CHASE3047 is offline
post #2 of 2 Old 10-26-2013, 09:44 AM
GilaMtnJeep
GilaMtnJeep's Avatar
Start by dropping the driveshafts and see if you can rotate all four wheels. Make sure each wheel can move individually. It will give you an idea where to go from there. Definitely sounds like a drive train issue.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
